Im thinking about getting this camera but I would like to hardwire it to my interior fuse box.
Do you think this product is a good one for this or do you have a recommendation?
https://www.amazon.com/gp/B00MH4ZVHO
Is the ferrite bead really all that important? The CPUSB01 doesn't feature it.
i have that mount and i tried using it a few years ago for the GC also. Do you have much "shaking" the way you have it? I didn't flip it around, i just stuck it on so the cam sits right over the bubble. it gives a bigger gap between the glass and lens, but i figured it would be very stable that way.The Escort mount arrived today, seems well built.
At first it appears the mount won't work, but the flat surface can be removed and flipped over as both edges of the bolt hole have serrated edges to lock into place when tightened.
The adhesive seems plenty sticky, the Escort clears the wires, and I cut some of the protective film to cover the exposed areas.
I'll use it tonight and hopefully get some footage posted, also try to compare it to my Dexors X7.
Something I forgot to ask.....does the Street Guardian come with a remote microphone? I have a GPS antenna, short 3.5mm extension cord...but no external mic....but have a port for it.
P | How to remove write protection to reformat SD card in SG9665GC? | SG9665GC | 7 | |
J | SG9665GCV3, power light comes on but no boot screen | SG9665GC | 4 | |
P | SG9665GC v1 and v2 Memory Cards | SG9665GC | 4 | |
A | Street Guardian SG9665GC V2 flashes power and mic light then turns off | SG9665GC | 5 | |
SG9665GC V2 Finally dead... | SG9665GC | 0 |
