Just saw sandisk make a dashcam SD card
kamkar
Denmark
+1 decade, many dashcams
I just tried a test purchase for that new microSDXC. SanDisk is doing some creative pricing. The page shows a slashed 46.99, with a retail price of 36.99 for a 128GB card. Add one 128GB to the cart, and the price in the cart shows a slashed 64.99 with a new retail price of 49.99. Pricing magic carries on if you sign up for the newsletter and get 10 percent off.
Meanwhile, Amazon has the SanDisk Max Endurance 128GB at 36.99. SanDisk once told me that if Amazon is the seller, then the memory was authentic.
The average dashcam user will never need more than a 128GB memory card.
...The average dashcam user will never need more than a 128GB memory card.
This is true if you consider only the amount of video that can be stored. However, once you factor in media life things change.
Flash memory has a finite life span based on the number of write cycles. A given memory cell an a card will be written half as much on a 256GB card versus a 128GB - therefore the expected life span is doubled. Do it again for 512 versus 256. Depending on pricing then a larger capacity card may be the better value over time.
I am firmly behind 256 GB for anything Dahscam, even if just 1 channel.
And especially if you are into parking guard, well at least with some modes.
I generally use 256 GB for almost all occasions now. If I have a longer drive or a period when I don't want to, or won't have the time, then I use either 512GB or 1TB.
For the money-conscious user, 128GB will work quite well. If I were a UBER or LYFT driver, I would go for 512GB or larger, or, if possible, an external SSD.
External SSD, just not with a Viofo until it's all sorted out or other manufacturers jump on board haha
At that cost, I would choose Max Endurance version for the same capacity with 15 years of warranty !๐Ÿ™‚
This.
Seems like marketing fluff by SanDisk here, taking full advantage of the memory crisis. Will see if the naming catches on with other brands...
Okay just browsed new memory cards at a local retailer ( proshop ) and it seem like Sandisk pretty much revamped their entire lineup
Interesting article there. Speeds are faster, but usually that just means you have to use their reader or whatnot to achieve those faster speeds.
Agreed. The secondary factor is "leeway". If you can't stop immediately after an event, or for parking mode, you don't want the footage overwritten. Having a large enough card gives you flexibility.
