Something's not right with that info. I've been using one of those cards for 2 years and 7 months in several dashcams and never once had such a problem. Or any problem whatsoever, for that matter.I am not sure if this is your card? https://www.amazon.co.uk/gp/B0162YQG2I
The read speed is given as 45Mb/s and write speed of 10Mb/s which isn't going to be fast enough unfortunately (taken from Kingstons website).
......Kingston cards usually aren't fast enough for continuous recording......
I've just compared mine to the image on the amazon link NextBase Tiffany posted and the latter seems a bit fake, to be honest.I agree. Their fast on-paper figures are based on short bursts of read/write on an unfragmented card, not prolonged periods of write/overwrite with fragmentation.
Memory cards weren't developed for the heavy-duty needs of dashcams.
I find Samsung and Transcend cards are good workhorses in most dashcams.
That is if the card's real write speed is 10Mb/s, which I don't believe it is, otherwise mine would've started failing a long time ago.I will explain why it is so important:
For the 212 (each model will be slightly different) each 3 minute file is around 360Mb,
There are 8 bits in a byte, so 360 x 8 = 2880 Megabits of information to write to the card over the 3 minute period,
There are 60 x 3 = 180 seconds in 3 minutes,
This means that 2880 Megabits need to be written over 180 seconds leaving an absolute minimum write speed of 16Mb/s.
That of course would still struggle to perform the loop/overwriting function, your cards write speed is not capable of writing HD files unfortunately.
To perform the loop/obsessive rewriting that dash cams need we recommed 48Mb/s or more.
This model doesn't have motion detection unfortunately.
What is the write speed of that card? User images on Amazon suggest it averages less than 20Mb/sHi @MikeyI
Sorry to hear this, what write speed is the card your using?
I have attached a link to a compatible SD card, we use this one to test our models.
https://www.amazon.co.uk/gp/B013UDL5RU
The info provided by Tiffany is not correct. The Kingston card has a minimum write speed of 10MB/s, not 10Mb/s. Her calculations about the camera's write speed are correct but the final result, 16Mb/s, equals to only 2MB/s, so the write speed of your Kingston card is more than adequate for the camera's needs and won't affect the insurance policy's conditions.My main point though Tiffany is that there are thousands of Nextbase users out there who rely on the cams to comply with their insurance, but don't know the 45 MBs requirement and so will not have suitable recording happening as per the OP's issue. This legally renders them uninsured as the policy conditions specify "working dash camera that can supply footage in the event of an incident". I would suggest that Nextbase need to push this information to all purchasers as a matter of urgency, and further make it very clear on the packaging/instructions going forwards that lower than 45MBs write specification cards will render your device inoperable for the purpose for which it purchased and may invalidate your insurance.
It's a Class 10 card, so the minimum write speed is 10MB/s.What is the write speed of that card? User images on Amazon suggest it averages less than 20Mb/s
The speed rating I mentioned is what sdcard.org says for Class 10 cards, not what Kingston, Transcend, Samsung or any other manufacturer says. If you're saying that's how sdcard.org achieve those numbers, then no card is compatible with dashcams, right?Note that the speed rating is based on the write speed for a short period of time on an unfragmented card.
Dashcams write for prolonged periods of time on fragmented cards.
The two operating conditions are very different.
Think of a Kingston card as a 100 metre sprinter and Transcend/Samsung cards as long-distance runners. The Kingston may achieve the highest speeds but it can't sustain them for long periods and eventually it can't keep up with Transcend/Samsung.
