kamkar
- Oct 11, 2013
- Denmark
- 10 years, many dashcams
So it seem like no changes to settings will stick after the camera have been turned off and then on again.
Also removing the battery will reset the clock timer.
I have a feeling this is all down to the same missing thing in firmware.
Most things you can change and have them work just fine, but if you turn off the camera it is back to default when it boot up again.
But gyro sensor / image stabilization dont seem to be working even just after you made the change, and off course this too dont get saved when you turn camera off
The way you change date/time and wifi name and ssid seem troublesome and slow, but off course it is not something you will be doing often.
I would assume the camera is supposed to boot with the changes made in the last session, but as nothing is saved the camera boot with default settings.
Recording stuff.
The camera do a great job with a few things to mention.
1: the default color scheme seem a bit over saturated.
2: 1080/120 seem like a frame or two is dropped now and then, but i am not sure if this is due to the low daytime light up here, will be keeping a eye on this in the future.
WIFI / camera - phone/tablet connection is working good for me, preview also look like it have less lag than other cameras i have tried with wifi
If lag in preview could be made less down the road it would be nice, but its not a feature worth spending time now, other more important things to look at i would say.
I am not quite sure if my adjustment of the focus is in the sweet spot yet, its so dark and grey outside that the camera always use slow exposure timings, so it is hard to tell.
So will have to keep a eye on this before i fix the lens in place again.
Recording stuff.
