gcb
- May 5, 2016
finally fixed the "lcd off" feature and got rid of the bright pink clock on all the time.
http://cubeupload.com/im/35cLnS.jpg
While opening it up, i also realized that the heat spreader (the metal you can see there, which would be under the LCD) was NOT touching the CPU thermal pad! there was over 1mm of gap.
that lack of quality control and probably a bad batch of cheap thermal pad may be the problem with everyone getting even more noise than normal after 20min!
anyway, to also solve that, i put a piece of foam pushing the heat shield down. if that even is a heatsink... i assume so because of the thermal pad... anyway, i also removed the sticker and drilled a few holes on the bottom to help with that.
only dumb thing i did, was to not properly record the key presses needed for somethings, like turning wifi on/off. and formatting SD card.
if anyone can type those here pls. i tried turning lcd on by
power on -> power/setting -> right button 4x -> power/setting -> rec/back
but it did not work. don't know if the first right button press change from resolution to the next or just move the cursor to resolution.
