As I said, I agree with Linus. Years have passed and we still are offered the same image quality, no matter the price.
Too bad they didn't include dash cams from 70mai, DDPAI, an similar in the comparison.
Image quality has improved, but now nearly every manufacturer is using the Sony IMX335 image sensor in their full range of dashcams, so the differences in image quality between the various dashcams have become even smaller. Lenses have also become far closer in quality to each other, and the worst SoCs have disappeared, thus making the SoCs closer to each other.
We will get a significant improvement only when one of the manufacturers releases a dashcam with a new image sensor that is a definite improvement over the IMX335, then the IMX335 will continue in the cheaper cameras and we will have a new set of more premium cameras with genuinely better image quality.
Currently only the Viofo A129 Pro with its 4K IMX317 stands out as being different, and for sunny weather it is definitely a big improvement, unfortunately the IMX317 isn't designed as a low light sensor, so is not ideal for dashcams. A229 Pro?
I'm of the same mind. I'm no expert but my research when I wanted to move away from vibrating stalk mounted cams and find a solid mount with good reviews pointed me to the Viofo A119 range.
Yes, the mounts are one of the things that are actually different between cameras, and some are much better than others.
The small number of lenses and processors shared across makes was interesting, is it true ?
Not really true, there is actually quite a big range of processors within the Novatek range, these days mainly differentiated by processing power and how many channels they can support, so dashcam manufacturers do have choices. And there is also a selection of other SoC manufacturers, Blueskysea use some of them to give great value, although Novatek seem to manage the best image quality for dashcams so they are what many manufacturers choose. Ambarella used to have great image quality, better than Novatek, but they failed on other factors for dashcam use so don't get used these days.
There is plenty of choice in lenses, the cheap plastic ones don't tend to get used these days except for the $10 cameras, and to get noticeably better than normal requires a fairly expensive lens, so they tend not to get used either. One of the main reasons Viofo do better on image quality is the quality of their lenses, always using decent anti-reflection coatings on all the surfaces.
