How do you delete locked files from the app? I've tried and can't seem to figure out how.Either take the card out and pop it into a computer, delete via the app or format the card in the camera
Sent from my SM-G950F using Tapatalk
You don’t have to format the card,locked files can be easily removed from the device itself(Viofo A129)don't delete files ad-hoc, better to format the card
Start the device+stop recording+press triangle to view files+select locked file+press triangle to open locked file+unlock file removing the key symbol,MIC button removes the lock symbol(on VIOFO A129)+delete unlocked file pushing REC button(on VIOFO A129).don't delete files ad-hoc, better to format the card
just format the card, it will delete everythingI have many locked files in the camera, but don't want to keep removing the SD card daily to unlock them.
Any way to select multiple files and unlock them all at once, rather than having to do it one by one?
A129 PRO Duo, btw.
Thanks
[SOLVED] 25s missing between 2 files... | A129 / 129 Duo | 12 | ||
R | Accessing files in the app | A129 / 129 Duo | 2 | |
Identifying locked video clips? | A129 / 129 Duo | 3 | ||
Remove locked videos | A129 / 129 Duo | 3 | ||
S | VIOFO App--Delete locked recordings? | A129 / 129 Duo | 6 |
