SawMaster
- Apr 10, 2015
- SC
- Numerous and ever-changing
The B2W is so far my preferred front cam, mostly because of the swiveling lenses and the overall good vids. Just reach up and turn either the front or cabin cam and capture whatever you want. It's not a small cam and the form-factor doesn't work for everyone but if you can fit it well you'll probably like it. The A129 IR has a remote IR cam on a very short cable, but the mount doesn't inherently swivel so you'd have to use a single screw mounting to rotate it. Better vids, higher cost. Most of the other "Uber" cams don't have a way to swivel the lenses; only up-and-down aiming is easy with those. The New W4K is like this, but I haven't seen owner-posted footage from the cabin cam and I don't have that option with mine.
You can always do some "MadMax" work with brackets and find a way to mount cams differently than intended to get normally unobtainable coverage. My old Mobius was such, and it could be swiveled 360 degrees. Almost always a way to do what you want if you apply enough thought to it
