@Mtz I've been meaning to ask where this change comes into play in the data-chain; is it implemented at the sensor so that you can lose the overexposure that comes from a bright sky, or is it later where it only 'crops' the view you see?
Wishing you a happy and prosperous 2021
Happy new year!
As you know, if you are moving up down the lens, the image will become brighter if pointed down and darker if pointing it up.
The new 21:9 AR (Aspect Ratio) is
cropping the vertical from 1440p to 1080p, but the image is still 2K, it is not just Full HD because of 2560! 2560x1080p from camera menu means UltraWide 1080, WFHD, 2560 x 1080,
Wikipedia. Just Full HD players will not play this video, a 2K player is needed.
Because the vertical of the video is smaller on 21:9 (compared to 16:9) the lens vertical adjustment is much more
sensitive regarding exposure errors because it contains
less sky! So when using UltraWide setting of the camera we need to be more
careful to assure the horizon line is 50% sky - 50% road because the exposure depends only on the visible area.
Regarding 2 channels encoding I see at least 3 advantages:
1. processor is using same bitrate as for 16:9 which means more bits/pixel which means better image for important recording area because dashboard or motor hood or sky is never important on the dashcam recording. Usually in dashcam world we are interested only about
1/3 size from the vertical image, around horizon line.
2. less dashboard, less sky not important for recording, less pixels the processor need to encode, less stress for processor should record 2 channels without any problem
3. more nice result if you want to make a video by using stack vertical from front and rear
Of course, because the IMX335 can output 2592 x 1944 could be interesting that processor to use whole sensor area and then to output the MP4 as anamorphic. More pixels from the sensor used, better image. But I think nobody is interested to offer anamorphic MP4, just is a shame that Sony created a 4:3 sensor and it is used only to output 16:9 or 21:9 images which means about 20% from the sensor area is not used, money lost.
enjoy,
Mtz
