I copied this from an old post that never got an answer.
I'm hoping I can get reliable loop recording with a Samsung 128gb PRO. After formatting in-camera with msetup, the software would not recognize it. I then formatted it with the SD Card Association formatter and it recognized it. It recorded fine the first time but there's one spot on my commute where it stopped then promptly started back again.
I've taken the following three sentences from https://www.mobius-actioncam.com/faq/ -
128GB cards will also work but cannot be correctly formatted to FAT32 using the built-in formatting routine (as of firmware v2.18).
It is recommended to only use FAT32 when loop-recording is enabled.
For optimal card performance it is recommended to always use the camera’s built-in formatter.
If I combine the logic of these three sentences, am I right in thinking a 128GB card cannot be used for loop recording and be compliant with the FAQ recommendations?
