Lots of beeping, not sure what is going on...
Damn Dirty Ape
Illinois
My x2 dual cam setup has been working great and this morning I open the car door to a double-beep and for the entire drive about 20 minutes I get the beeping like what is shown in the attached video.
The power, gps and rear cam leads are all connected, the rear cam in plugged in as it should be. Battery setting is 12v on the 3 wire box. Voltage checked shows 14.1/2 when idling and running down the road.
fuse tapes are firmly placed in the fuse block.
Ambient is about 65f, about 11am Sunday morning.
thoughts?
Video
It’s either a bad memory card
Or rear cable / camera is having communication issues. Check cable.
I will check the cable again, it appears to be securely pushed in on both ends I'm using a sandisk 400gb card as you recommended.
I missed seeing the video when I replied via iPhone earlier. I see one of the two 1080P on screen stamps vanishing while it beeps. You most likely have a weak/intermittent rear camera cable connection of some type. Is your rear camera fixed or does it move up and down via hatchback lift etc?
