LS300W-where do the red and blk wire from the LED attach on the motherboard?
AllThumbs
I opened my case and found the two wires from the LED hanging loose. If they have nothing to with IR mode, I will leave them unattached but taped up.
If I need to, I will try and take a good picture of the board, unless someone already available.
First thing i usually do when i open camera is cut ir-led wire.
Maybe take led off too, and put some black tape on hole.
Or just leave LED hole uncovered for cooling purpose.
I found what I needed. Fortunately the mfg of the motherboard stenciled a layout, in English, next to each component. Bat+. Bat -, Led+ Led -
I was very surprised at the circuitry, the only thing was the use of very thin wire.
Meaning a thin coating and very few strands of copper wire.
Thank you Problem Solved
