LTO (Lithium Titanate Oxide) – The Ultimate Battery for Dash-Cam parking mode (DIY)
I bought some of these to use for hardwire connection
. https://www.aliexpress.com/item/1005004386911405.htm
Maybe I'll just get a grommet to allow this to hang out of the enclosure, and I can also add a single wire butt connector for ACC through the grommet.
Maybe someone else can share their experience cutting metal?
I do this the same way, either I drill holes that never seem to line up exactly where I want them to, or I use my dremel with a cutting wheel (or a combination of the two).
Added a handy feature for the battery:
Two brass tubes 2.4 mm ID and 3.2 mm OD, are pressed into the front panel, protruding about 1.5 mm, about the same as the display next to them.
Hey, now THAT’S a clever design feature! I always have to open the case to make those adjustments, and it’s a bit of a hassle. This is a nice and clean solution!
Since I experiment a lot, I wanted to be able to easily adjust the charging current from the very beginning.
On the original 7S pack, I added a second CC resistor in parallel with the existing one and a switch, as shown in attachments.
By adjusting these two resistors, I could set any two CC values and switch between them.
However, on the latest charger, the CC resistor is not so easily accessible, and I was constantly wondering how to get to it.
Then it hit me, and now I can easily adjust the CC over the entire range.
Also just received a spare JK-BMS from AliExpress.
Same model as my original and the one I bought on Amazon.
It has a Chinese label but no manual, 10G wires soldered and no ears.
The Amazon version came with an English label, detailed printed manual in English, screw terminals with bolts, 10G wires with ring terminals and ears, and is 10mm longer than the Chinese version.
Both versions have exactly the same model number and specs, go figure.
@wilsch - could you please check the Bluetooth range of your JK-BMS in a closed case?
Recently I noticed that the JK-BMS version with P- and B- wires bolted on, (from Amazon, and similar to yours) has a very short Bluetooth range of about 8 ft in a closed case.
Also, the power switch stopped working.
So I removed it and replaced it with a spare JK-BMS with P- and B- wires soldered on (from China and similar to my original BMS that I used on a 5S battery).
Now the Bluetooth range is about 20+ ft (plenty for car use), which is comparable to the range of my original JK-BMS for a 5S battery.
Curious discovery about blutooth range. Inside the blue box really limits range for me as well. I have to be within 8-10ft. I used to be able to reach the EcoFlow with blutooth from the living room couch. I’m assuming the powder coated panels are thin gauge steel?
Curious discovery about blutooth range. Inside the blue box really limits range for me as well. I have to be within 8-10ft. I used to be able to reach the EcoFlow with blutooth from the living room couch. I’m assuming the powder coated panels are thing gauge steel?
Yes, steel plates but with venting slots and plastic frame helping with BT signal.
Using the same/similar case for a 7S battery with ANT-BMS, I got good range (never measured it though).
10 ft is not much, but probably good enough for a car.
Beside very good BT signal, at home, the Ecoflow switches to Wi-Fi, and I can access it from anywhere in the house, at work, and anywhere else I have a mobile connection.
To check the BT signal:
I removed the top cover of the case to see if there was a difference, and the range did increase to about 15ft, but still not as good as the original BMS for a 5S battery in a closed case.
Then I compared the Bluetooth signal strength (%) using BT inspector app, and it was about half that of the original BMS (both with open cases).
So I replaced the β€œnew-style” BMS on 6S battery with a spare β€œold-style” BMS with a soldered P-/B- cables and now the BT signal is as good as the original one. (about 20ft with closed case)
Therefore I thought maybe the limited BT range was a shortcoming of the β€œnew-style” bolted P-/B- wires version BMS.
Thanks to @Chuck McCoy for the post linked here (right on time):
I can confirm that my bluetooth range is rather abysmal with the newer hw version of the bms. With the case closed I get about 6ft of range provided there's no other obstructions. So with the battery in my car's trunk, I cannot connect to it unless I pop the trunk and hold a line of sight between the phone and battery.
Though, I dont often find a need to check on the battery status now that I have everything set up and running, so this limited range isn't too much of a hindrance for me.
Sorry for the late reply, I've been rather busy since finishing up the battery and installing it in my car. Soon I'll share an update on my completed battery and car installation πŸ™‚
Thanks for the reply.
So we have two identical new versions of the JK-BMS, both with very short Bluetooth range - apparently a shortcoming of this particular model.
Today, I have sent a request to SUPPORT-JK BMS regarding the very short Bluetooth range.
I have provided them with links to my orders for the new and old BMS as well as a link to this forum.
I hope they will respond.
It will be interesting to see your complete battery and car installation.
I'm curious to see another DIY LTO battery myself! I was just looking at the website for BattyerHookUp.Com and they have three varieties of LTO cells available, including some new, individual "naked" cells with tabs large enough for drilling for screw.
Ha - I just discovered for myself the reason that you included a UPS relay, @GPak πŸ™‚. I now have three cameras tied to my LTO battery and when I opened the app to see what the charge rate was while waiting to pick up my daughter and saw that the charge rate was only about 3.5A. This was strange, I remember setting to somewhere north of 5.0A, but that's not what I was seeing. I've also been noticing lately that the battery seemed to be charging more slowly that I was expecting. I knew I was drawing more from it, but I started wondering what was wrong. Is it the charger board? What was going on now? Sigh... Then I realized it was the impact of having multiple cameras running. As I turned them off one by one, my charge rate returned to 5.5A, just as I expected.
The 20w that were powering three cameras was being subtracted off of the 70w that was going to the batteries... I just have the cameras pulling directly from the batteries and the batteries are being charged by the charger/bms combo. I never put the UPS board in place because the draw of a single camera (when I built the box) wasn't really a concern... until now... πŸ˜‰
The bypass function using a UPS module has many advantages, but like everything else, there are also a few minor cons.
Connecting additional loads to the battery won't affect the charging current and charging rate, as displayed in the app, which is good, but it will increase the current draw from the vehicle's electrical system.
If it's an alternator, as in your case (the right way to install the parking battery), then this isn't even a real con.
However, in my case with the CLA, I have to be careful not to exceed the CLA's rated current, I am planing to replace my old jeep soon, so I don't want to bother with running wires through a firewall.
I think it's a good feature to have, and its benefits far outweigh the cons.
Yep, just reinstalled my hardwire connection to the battery and set the charge rate to about 9.3A. This tops out at about 145w of charging and with the ~20w draw of a few cameras, still leaves ~100-110w of power to charge the battery, depending on its state of charge.
Also, I think I discovered the "mystery" around that infuriating little orange LED indicator on the smaller 20A charger board that we both played with. Earlier, we were operating under the premise that it was some sort of "error" light, telling us something was wrong. After adjusting the charging current back up and watching things in the app as it was charging, I'm now thinking that the orange LED means that the charger is bucking the charge voltage (voltage delivered to the batteries is less than the input voltage to the board) and the LED goes out when the charger board starts boosting the charging voltage (voltage delivered to the batteries is greater than the input voltage to the board).
At my higher charge rate, I don't think I'm going to play with adding the UPS module. There isn't a practical benefit now. For a short time, I was back to using the utility outlet and I was being careful to keep the current draw below 50% of the power rating for the socket.
I noticed this too, but I wasn't sure because the LED switching from orange to green wasn't presisly synchronized with transition from buck to boost. In my case, as far as I remember, it would switch to green a little earlier, while still in buck mode.
At the time, I couldn't find anything about this in the product description.
Meanwhile, I finished working on a 6S LTO extended battery to test the extension concept, and it works.
I'll post the details soon.
I have completed building an extended battery for my original 6S LTO dash cam battery.
Everything works as expected.
After connecting to the main battery, the total capacity in the BMS’s app needs to be updated from 20 Ah to 40 Ah.
Then, the app will display a message stating that the BMS will re-calibrate during subsequent charge/discharge cycles.
The extended battery is the same 6S LTO configuration as the original one, but greatly simplified:
-No 5-pin, SPDT, 30A time delay relay and the XT60-I and XT60 input connectors;
-No DC to DC, 25A charge controller module;
-No 40A, BMS;
-No 8A, bypass UPS module and the 3-pin 12V output connector;
-No USB-C-PD/USB-A-QC3.0 module;
-No Battery State of Charge (SoC) and voltage display;
+Added active balancer with individual cell voltage display;
Here is the video showing the extended battery and how it works:
To better understand the extended battery, check out posts #372, #374, and #375 on the original 6S LTO battery.
It’s been over 9.5 months since I installed Ecoflow River3 in my Jeep, powering two Viofo Mini2 dash cams via two USB-A ports using HK4 cables with removed voltage regulators (my original 5V direct connection system).
It worked flawlessly the entire time.
It survived both winter and summer, with sub-freezing charge protection tripping once and overheat charge protection tripping twice, while still powering the dash cams in both cases.
I love features like Wi-Fi and Bluetooth and app, the ability to remotely turn off the battery and the dash cam(s) when not needed, the ability to change the charging current on the fly via app, time-out, port memory, and the pretty accurate state of charge indication.
It is easy to install and maintain.
Overall, this is an excellent power station for a dash cam, much better than any dedicated battery on the market in my opinion.
Now the time has come, and today I replaced it with my DIY, LTO battery.
It's a simple drop-in replacement.
I didn't change anything in the car's wiring.
The LTO battery is powered via the same CLA-XT60-I cable, and the same two USB-A dash cam cables are connected via a Y-splitter to the USB-A (QC3.0) port on the LTO.
And here is the awesome part - totally plug and play!
On a related note, since I've been running multiple cameras in my car for a while now, which runs down my 6S LTO battery a bit more quickly. I've been contemplating picking up the 24 cell LTO battery at BatteryHookup and reconfiguring it just a bit so the overall arrangement of cells is a 6S4P, resulting in an 80Ah pack at 1104Wh. Is there a particular reason that I should not put the cells in parallel four at a time? I realize this reduces the ability to manage each cell individually like I do now. I was just thinking it might be easier to keep the cells in their "original" container and strap a charger, BMS, diode, etc to the top in another small container. Maybe I'm just trying to be too lazy...
The 6S4P battery, according to your sketch, will work fine.
There's nothing wrong with connecting four cells in parallel.
The BMS will be connected using a regular 6S1P setup.
All parallel connected cells will be at the same voltage and will be protected as one.
The resistance of the blue cables in the sketch should be comparable to the busbar resistance. (meaning big wires)
Note: the center left busbar still needs to be cut as shown in the sketch.
With so many dash cams in your car, you may need a more powerful charge controller for this battery. πŸ˜‰
Thanks @GPak - I wasn't sure about the 4P part. This will keep all 4 cells at the very same voltage level. I'll need to change the BMS capacity to 80Ah instead of 20 to account for the cells in parallel. My plan is to solder some 10g or 12g wire to the existing busbars - I have to look and see what I have in my parts box. Understood about still cutting the center busbar closest to the connection terminals. Cutting that connection and joining the two "sides" with wire jumpers still enables the original battery connection posts to function as intended.
Just ordered the battery pack today, it should arrive in a day or two, BatteryHookup is less than 100 miles from my house. I'm trying to weigh the merits of keeping my original battery pack intact and having 2 batteries vs canibalizing the old battery parts into the new one. I'm curious to see exaclty how the 24-cell pack is arranged and what kind of connections are available. I'll post some detailed images.
Just running some numbers:
6S1P with a single dual-channel camera gets me a bit more than 50 hrs of record time (which has been great), but running 3 cameras pulls that down to about 15+ hrs, or just barely 2 days.
6S4P should get me closer to 65+ hrs with three cameras running.
I never anticipated this "drawback" of living only 3 miles from work 🀣
Found this add-on box with mounting flanges that might work well to hold the BMS, charger, and connection ports. It's available in different sizes, should be easy to connect to the lid of the battery pack so I can leave the batteries in their existing enclosure.
https://www.amazon.com/gp/B0CQFYMLKG
For such a large capacity, you may want a 25A charge controller in case you decide you need faster charging.
It looks like the number of dash cams in your car will only increase. 🀣
If you buy a new BMS make sure it has soldered power wires, the bolt on model has a very weak Bluetooth signal/range.
I think aluminum case would be better than plastic one, at high charging currents (if you choose them) the charge controller may get too hot for plastic, hopefully @wilsch can provide his incite as he was planning to charge at around 20A.
And yes, please post as much information as possible; this is very interesting.
I'm considering building a high-capacity UPS based on an LFP or LTO battery for all my office electronics, such as the TV, computers, printer, Wi-Fi modem/router, etc.
This 24V LTO unit would be a good option for the battery, if only I could find suitable AC components.
I'm on the hunt for a BMS with attached wires - I remembered your warning about the crummy Bluetooth signal πŸ˜‰
Did you say that the newer/larger 25A charger board has an anti backflow diode in it?
I was debating between a plastic and metal case for the BMS, charger, time delay relay, input & output connectors. If I go with plastic, I'll likely cut a hole in the side of the box and attach a heatsink directly to the charger board and have the heatsink stick out from the box. It all depends what I can find that looks workable. My plan is to use screws to attach the additional box to the top of the battery box to keep things from shifting around in the trunk.
I'm thinking I'll use a set of dual-row spring loaded speaker terminal clips as the +12v connections for hardwire kit (yellow and red wires) and a grounding lug for the black spade clip ground connection. Maybe something like this so I can easily connect multiple hardwire kits in parallel.
https://www.amazon.com/gp/B082655BXN
