EricSan
- Dec 28, 2023
- Central PA
Pfew! After spending nearly the entire day, I've rewired the LTO battery for my son's car. The biggest amount of time was just finding a place through the firewall into the engine compartment. I could find the rubber grommet on the inside of the car, but it was difficult to find where it came out near the engine. Turns out that we had to remove the front passenger wheel, the wheel well liner, the battery, and the battery holder! The rubber grommet had an empty little tube for adding wires, so we snipped off the end and then spent lots of time trying to stuff the new wire through.
I purchase this wire from amazon. It's pretty impressive: it's labelled as a two conductor 12g wire, but it is actually 11g (4.0mm sq cross sectional area), and has three layers of heat-resistant insulation. There is an outer weave that goes around both conductors that is supposed to be flame resistant and is rated to nearly 400F , then each conductor is covered in two separate insulators that are supposed to be good to about 250F. It's pretty substantial. The resulting two-conductors plus external sheath is so thick that it took quite a lot of effort to pull it through the rubber grommet in the firewall, it nearly didn't fit at all. The fit is so tight that it didn't need any tape or caulk to seal the grommet afterward. My original 12g wire is on the left, the new 11g wire is on the right. There is a substantial difference between the two.
I crimped ring terminals to each conductor and connected them directly to the battery terminal hardware under the hood. I was able to connect the ring terminals to the battery terminal clamps so that it won't be any extra work at all to change the battery. I added an inline fuse to the positive wire just a few inches from the battery and installed a 20A fuse. Inside the car, I tapped the fusebox for an ACC switched power supply and used this to power a time-delay relay that I inserted into the hot leg of the new power supply wires and tucked them up under the glove box with a few zip ties.
The LTO battery charges to 16v at 8.0A, for a total draw of about 120w, plus incidentals and efficiency losses. The new power supply should be able to handle this without any issues at all: it's all 11g wire with a straight shot to the battery that is ACC switched with a 40A time-delay relay. No more fiddling with the utility outlet and plugs that don't fit/hold as tightly as they should... No more worrying about the utility outlet wire being too thin- I'm guessing it is a maximum of 16g, more likely 18g. After all of this, I'm hoping that I'm done fiddling around and "fixing" things now!
This is what the EcoFlow utility plug looks like after it melted last week. It's a shame that it died, it was a pretty nice cable otherwise...
