Lukas CPL recommendations
Re: Lukas CPL recommendations
Jazzist said:
Found this on the Lukas website.
http://lukashd.com/gnuboard4/bbs/board. ... fo&wr_id=2
Sent from my GT-I9300 using Tapatalk 2
Nice find. I've had good results with my Lukas 7900 and a CPL. I have a B&W CPL 52mm attached using a step up ring
http://www.bhphotovideo.com/bnh/control ... details&Q=
from 37mm to 52mm so it changes the appearance of the camera to a large degree. This does completely illuminate vignetting which I think is a plus.
I'm have no idea who makes the CPL sold by LUKAS but I would imagine it's an economy brand which may not be the best choice. With these filters it's always best to go with the best one your budget allows.
why just a step up ring from 27mm to 52mm, coincidence?
I have from my Canon 58mm, 27mm to 58mm which is too large?
Cam takes 37mm.
Sent from my Nexus 7 using Tapatalk HD
Al Drake said:
Jazzist said:
Cam takes 37mm.
my bad. I must have typed it wrong.
Don't think so? 🙂
I already have many 52mm filters so I got a step up ring to use them on the LUKAS which takes 37mm. Now the LUKAS can use all the 52mm filters I have.
sorry, that was a mistake on my part. I just wanted to know if the bigger the better?
why just a step up ring from 37mm to 52mm, coincidence?
I have from my Canon 58mm, 37mm to 58mm which is too large?
Actually I just ordered another CPL and step up ring for my second LUKAS LK-7900. I find that the availability of quality polarizing filters in a range of 52mm is greater while still small enough to keep the price down. Again the step up ring will completely avoid vignetting that can be slight using a 37mm filter. I have large CPL filters for my DSLR telephoto at 72mm and they can be rather expensive. I can also imagine what one of those would look like on a dash cam if they even make a step up ring for that combination.
