superpat
Hi,
I have used my Lukas LK-7900 for some weeks and I am still dissatisfied with the quality of the videos produced.
The problem is lack of detail ( lack of sharpness) in the image recorded. It looks blurred.
I have run the gamut of adjusting the ALL the settings and although I can vary the quality, I can never achieve as good an image as the little DR32 I also have.
Today whilst I was staring at the latest video using the Ace Viewer, I suddenly realised:-
The image of the plastic air vents and bezel on the surface of the horizontal part of the dash board just in front of the bottom of the windscreen glass is ABSOLUTELY BLOODY FANTASTIC! It is extremely detailed and pin point sharp. Very clear and not blurred.
( This is not the reflected image in the windscreen, but a primary image, The air vent and bezel is about 6 inches in front front of the LK-7900 lens (in the horizontal plane, but about two feet down. My windscreen slopes at an acute angle.) The air vent and bezel appear at the bottom of the video frame. Another possibility is that the lens / image sensor are not aligned in the same plane and are tilted in the vertical direction, with the best focus at the bottom of the frame.
My windscreen is perfectly clean both sides.
The only realistic conclusion I can come to is that my camera is focused at its sharpest point at about 6 inches in front of the lens !!!!!
I think I will print off a copy of a focusing target from the web and take some video with the car static, moving the focus target back from touching the windscreen to a few tens of yards away.
Is it possible to adjust the focus of the camera lens? Or is it glued in?
Just looked again at the jpg I have attached... I'm not convinced its a simple focus problem. The focus does not get worse the further the objects are in front of the camera, they appear uniformly bad at whatever distance... I am really baffled now.
Relevant comments and help appreciated please.
cheers
Patrick
cheers
Patrick
