toyon98
This is LUKAS PRO LK-5900HD, which is a black box for automobiles. It's the first black box in South Korea that can install a CPL filter on it and it's a black box that helps to enhance the resolution.
This is the box of LUKAS PRO LK-5900HD. The box is very strong and it looks very luxurious.
The specifications of LUKAS PRO LK-5900HD are written on the back of the box.
This is the seal that's on LK-5900HD's box. It's seal that tells us that it's a fresh product. It looks like the case has become a lot more luxurious this time.
I opened LUKAS PRO LK-5900HD. The instruction manual is the first thing that you see when you open the box.
The components of LUKAS PRO LK-5900HD LUKAS PRO LK-5900HD / Power cigar jack, double-sided tape and clips for fixing the black box, 16gb memory, Lukas stand, Lukas instruction manual.
The design of LUKAS PRO LK-5900HD Let's take a look at the design of LUKAS PRO LK-5900HD. All of the products of LUKAS have a similar design. This is how LUKAS PRO LK-5900HD looks like from the side. The small oval switch on the side is the emergency button.
The back of LUKAS PRO LK-5900HD Black Box. The sticker and the display screen are on the back. This is where LUKAS PRO LK-5900HD will get combined to the stand. It is a built-in GPS.
This is the SD memory card slots of LUKAS PRO LK-5900HD. The basic lens is built-in in the lens.
There is the video output on the side. The on and off switch is right next to it.
These are the filters of LUKAS PRO LK-5900HD. The left is the UV filter and the right is the CPL filter. The video output cable of LUKAS PRO LK-5900HD.
When LUKAS PRO LK-5900HD has been installed on the car. Unlike the previous black boxes, it looks a lot more luxurious now because it has gone through the gloss processing.
LUKAS PRO LK-5900HD can record the videos in high definition. It has applied the F1.88 lens and you can secure a wide angle of view because it supports the angle up to 132 degrees. You can also install the 37MM filter on the black box. It has a built-in GPS. The black box switches to the park mode automatically without having the press the button.
