Tony lovelock
- Jan 18, 2017
- Hampshire
- United Kingdom
- Nextbase 422gw/Nextbase 212G & möbius C3 wide angle lens
Mobius ActionCam V3 1080p FPV Video Camera w/ Extra Wide Angle Lens (Type C2)
I currently have my möbius in dash cam loop recording mode,3 minute segments,auto record on both)!start up delayed,power off 30 seconds. I'm using a genuine tomtom USB cigarette charger adapter, with a 4 meter (eBay) mini USB standard lead to charge/record when plugged in. It will start to record ok for most journeys, but on the odd occasion it will record first 9 mins or so and then will go straight into photo mode with solid orange led.
I have:
Möbius magnet mount
Möbius weather cover
Kingston class 4 micro sd 32gb
I can't remember if it has the battery or super capitactor
The above is the action camera which I brought last may from hobbyrc.co.uk
I have updated it to the latest firmware, done an format via the msetup whilst plugged into laptop. I tried using the supplied awg triumph cable supplied by hobbyrc and it worked faultless, if I use my 4 meter eBay lead and move the camera around it will go into photo mode? Not sure if the mini USB port inside the möbius is worn/loose?
Any thoughts would be appreciated
I have:
Möbius magnet mount
