m6+ keeps restarting itself over and over
Discussion in 'M6 Plus' started by lawdubs, Sep 13, 2017.
  1. lawdubs
    lawdubs New Member
    2
    Country:
    This cam is around 8 months old, and has randomly started restarting itself with the sd card in. It will play the shutdown noise and then restart without the "hello ddpai" thing. After a few more seconds, it will shutdown again and it continues to repeat the process over and over. When I take the sd card out, the cam stays on and no longer restarts itself. I only have 1 sd card, so I'm not sure if that's the issue. Also, I reformatted the SD card on my laptop to no avail.
    Does anyone know what might be causing this? I've looked at a couple of Amazon reviews and have seen others mention this issue, but no one has any sort of explanation on why it's happening.
    Thanks for your help!
  2. jokiin
    jokiin Well-Known Member Manufacturer
    35,704
    17,884
    Country:
    China
    Dash Cam:
    Too many ¯\_(ツ)_/¯
    try another memory card would be the first test, if it still has issues look at the power supply or potentially failing battery is the next most likely culprits
    lawdubs likes this.
  3. lawdubs
    lawdubs New Member
    2
    Country:
    Issue fixed. Turns out it was due to a faulty USB cable. The cable provided with the cam for some reason stopped working. I used another USB cable and now the cam holds power and no longer restarts.
  4. jokiin
    35,704
    17,884
    Country:
    China
    Dash Cam:
    Too many ¯\_(ツ)_/¯
    common problem if they use CCA wire instead of OFC wire, the wire eats away at itself and corrodes which adds resistance and causes a voltage drop
    lawdubs likes this.
  5. Hombré
    Hombré Active Member
    643
    148
    North East NSW
    Country:
    Dash Cam:
    VIOFO A119S = Version 2
    Learn something new all the time including cheap rubbish is everywhere unfortunately
    jokiin and lawdubs like this.
  6. jokiin
    35,704
    17,884
    Country:
    China
    Dash Cam:
    Too many ¯\_(ツ)_/¯
    there's an unfortunate trend where a few cents saved on a component is seen as a good thing, a few cents here, a few cents there, times 10,000 piece production, it all adds up
    Hombré likes this.
  7. Hombré
    643
    148
    North East NSW
    Country:
    Dash Cam:
    Yup and going cheap can only add up to constant time consuming complaints all for a few cents less is crazy
    You guys have got it sorted
  8. jokiin
    35,704
    17,884
    Country:
    China
    Dash Cam:
    Too many ¯\_(ツ)_/¯
    it's false economics, no doubt about that, very common though
    Hombré likes this.
Share This Page
