Mass storage shows on charging then turns off.
WebsiteHippy
Spain
Hi
I have had an LS300W for about three years...has been working fine.
For no apparent reason, the battery will not re-charge.
I have tried charging up connecting it to my laptop....with supplied usb
While connected 'Mass Storage' displays if dashcam is ON, and
blue indicator displays if dashcam is switched OFF.
Blue charging light goes out after a few minutes.
Dashcam displays 'Low Battery' when switched on if not connected to laptop.
In short, it will not charge.
Any advice would be welcome.
Regards from sunny Spain
jokiin
Too many ¯\_(ツ)_/¯
three years is good for the battery, put a new battery and it will likely continue to work, the battery will cost a few dollars plus your time to swap it over, not too hard to do
W
WebsiteHippy
Spain
Hi Jokiin
Thank you for your rapid response.
I never thought of that..pretty obvious really.
Regards
jokiin
Too many ¯\_(ツ)_/¯
good chance when you open it up you will find that the battery has swollen, common problem, three years is a good run actually
meph DOD LS300 5
