HangFire
I received my eBay e-prance Mini on Oct 23rd after a long wait from ordering Sept 13th.
When I first looked at it I couldn't get anywhere other than let it power up when attaching power. So, I just let it charge.
I took a longer look at it tonight and after about 6 tries got it to get into the menu (long press button up). Then it locked up.
After a similar number of tries I managed to get it into some of the menus and one time managed to get the time set. But now it's back to- into a menu and then lock up before I can set anything. Once locked-up the only thing I can do is power down by removing power or holding the power button down for several seconds.
Other info... From my PC I ran the hw test on the memory card overnight and it came back with zero errors. The lockup behavior is the same on USB power from my PC as from the included 12V adapter in my car.
If it started recording I might be able to put it to use, but it doesn't.
Any ideas, tricks, something I'm doing wrong, or is this just a bad example that needs to be RMA'd?
