And as is often the case, higher quality comes at a higher cost. That could be the case with the Viofo cards, but we will only know that for certain in a year or two 😉.
You only need to stick the cards in a fast card reader and do a speed test to find that the Viofo cards are both exceptionally fast and exceptionally consistent in their fast speed, unlike other cards!
Unfortunately, microSD card manufactures seldom communicate the type of NAND they use in a specific card. Which makes it harder for us to guesstimate which card to use.
The Viofo cards, until recently, used to be described as industrial MLC, which was the explanation for them being fast with long lifetimes, however there was a size limit with that technology, and they are no longer described as MLC, just "industrial high endurance", so I assume that like all other cards, they are now some form of 3D NAND, and it is probably too complicated to explain how they get their speed and endurance!
Viofo said:
VIOFO industrial high endurance microSD cards, optimized for dashcam recording, give greater assurances around compatibility and long-life durability, greatly elevating your dashcam owner experience.
And, it could very well be that the technology that is used nowadays, to get to larger storage sizes, wares out faster than techniques used 5 years ago.
My expectation is that they last about the same time as before, with about the same number of writes per card, but less writes per cell, thus allowing higher capacities with the same card lifetime (number of recording hours) when used in a dashcam that uses loop recording.
Am I reading this right? These cards will only last 1-2 years? That doesn't sound right. Cards I've used on my Street Guardians lasted for many years and never failed.
That would be 1-2 years of continuous normal recording. If you don't use parking mode and don't drive 24 hours per day then you will get a lot longer, if you do use parking mode, but use low bitrate or event triggered then you will also get a lot longer. And of course a camera that records at 4K + 2K + 1K like the A229 Pro set at maximum bitrate is going to wear the card out a lot faster than an A119 Mini 2, and that is going to wear the card out a faster than a Street Guardian!
I suspect that lifetime does also depend quite a bit on temperature, very hot places are not good for memory cards.
This is concerning. if you wanna get a 512Gb card, the only "recommended" one I can find is VIOFO and it costs over $100. The San Disk MAX Endurance only seems to go up to 256 Gb. I have the 3-channel cam and need all the card space I can get. So we basically cannot use any other brand 512Gb's on this thing?
Viofo have tested cards, and monitored customer experiences, and their list of recommended and not recommended is compiled from experience and is regularly updated. Given that you are using 3 channels, it is wise to follow their advice, the general purpose cards sold by Samsung/Sandisk/etc. are not built for 3 channel dashcam use and people do have problems with them.
Yes, it is concerning, we seem to have reached the limit of the current microSD cards, and actually passed it in most cases. What memory card am I going to use when I get my 4K 60fps HDR10 4 channel dashcam? Hopefully Viofo will have that issue sorted by the time they release the dashcam
