I have been told that the samsung evo is a risk because samsung will void the warrenty if they discover the card is used in a dashcam. They are not publishing that, but a vender called and was told this by a samsung rep. A bit shadey to not be upfront on packaging and marketing. I too was looking at this card for my new viofo 129 duo.
I opted for the Transcend high endurance 64gb with the MLC nand, class 10. Then took a risk on a second card, the transcend premium 400x 128gb, class 10, but only tlc nand..
. I have a 1.25 hour commute (1 way) and plan to set it up in parking mode at work. I was concerned the 64gb might not be enough to run the dual cameras and park mode. SO now i have both options to play with. Worst case I have a back up on hand.
Oh and avoid the lexar SD cards... they are having massive issues. Also sanDisk "ultra" is not good either. SanDisk high endurance is fine, but does not use the MLC nand. Seems they are a bit guarded about releasing info on what cards use the MLC, so folks are assuming this means they are NOT using MLC in most if not all
