Buff Hamster
- May 15, 2016
- Australia
- Mini 0903, 0807, 0805P, 0801S, Viofo A119S, A118C, A129
Does anyone know if the Sandisk Extreme pro 128gb cards use MLC or TLC?
Thanks for sharing! A dashcam manufacturer's experience is valuable. The 400x are good cards for those looking to save a few bucks, as you get a quality card at an affordable price. But their lifetime warranty is void the moment you put it in your dash cam, and it's TLC planar NAND with no provision for endurance. ECC is a fantastic feature, but I'd rather start with an inherently more reliable design and then add ECC to that.
Yeah, I know, you can get a 128GB Transcend 400x for the same price as their 64GB High Endurance. If you went the 400x route I'd definitely recommend going for the larger capacity. But for the same money I'd rather have the 64GB MLC high endurance option. I want my dashcam to be as set and forget as it can possibly be, and the extra peace of mind would be worth having "only" about 10 hours of video on the card. And if for some reason over the next couple of years I ever have a problem, I know there will be no trouble with the warranty. I have a feeling it wouldn't be hard to get one of their 400x (or 633x) cards replaced under warranty, either. But I'm a believer in using the right tool for the job.
I'm really hoping Samsung's V-NAND microSD cards end up being as solid and long-lived in practice as they should be in theory. That would mean a fantastic new option with massive capacity and inherent endurance and more speed than you could possibly need in any dashcam for the foreseeable future.
By the way, if anyone knows of any other options for High Endurance MLC NAND with ECC at 64GB for a reasonable price, I'd love to add it to the list. I can't seem to find anything other than Transcend.
Samsung Pro used to be MLC, possibly the 64GB still are, but I suspect the latest ones aren't, however it doesn't really matter as long as they provide over 2x the lifetime of an Evo like they used to do. The latest 3D NAND can use far larger cells than previous 2D memory of the same capacity since they can stack maybe 64 cells on top of each other, the larger the cells the better the lifetime and reliability, they don't necessarily need to use MLC to get the lifespan and reliability required of a Pro.Not being uber technical.
I bought two “Samsung Pro Plus” ( according to Samsung this is the newer version of the “Pro +”
They got very coy about if this was an MLC card.
It has a read of 100MB/s and a Write of 95MB/s , Class 10 UHS-1, U3 and a 10 year Guarrantee.
I went for the 64GB version ... pretty much my budget max. As my camera is 1,440p 30/60 fps HDR ( apparrently merged??) so I assumed a reasonable bit rate.
They work well on front and back camera (both Vico MF3).
Just interested as they were bought in a rush ( from Samsungs prefferred reseller ) £32 each.
I was going to get the Samsung EVO plus at £19 but that has a write speed of 60 MBs.( thinking of one day have a decent 4K 60fps camera.)
Are these good dashcam cards?
Are they MLC as some say?
I probably wasted £12 a card, due to lack of research time, so overdid the future-proofing? Should have analysed a vid from this camera ... but heck you need a card to do that in the first place.
Note
I do use 4 Samsung Pro SSDs as “interim” back up drives on my Uber fast xenon CPU, NVME SSD based photography server. And they touch wood havent failed over the last year.
The Pro will still be a good buy if you use it enough to wear out an EVO, if you only record 30 minutes per day then an EVO would easy last 10 years, if you are recording 24/7 then the Pro is definitely a good choice.
"I do use 4 Samsung Pro SSDs as “interim” back up drives"
Note that you shouldn't use flash memory for long term backups, especially if the drive is not often powered up, flash memory looses it's image given enough time.
They do have a special line for dashcams and surveillance systems, but they still void the warranty for dash cams: https://www.sandisk.com/home/memory-cards/microsd-cards/high-endurance-microsd
When i bought the 750S 2 weeks ago, they tried to sell me a 128 GB Samsung Evo.
The price is about $64. I did not buy it.It's an excellent card so how much was it and did you buy it ?........... This is the one I bought cheap as chips........ https://www.amazon.com/gp/B06XWZWYVP
Viofo A119sWhat camera do you have?
