Mini 0806 died, only blue LED, no display!
itskv
This morning on my commute, maybe 15 mins of it being ON, it made a very weird loud hissing/screeching (almost like boiling) noise. I immediately went to check the status of the dash cam and it was extremely hot! (it was sub 60*F today) there was no more LED indicators on... Pulled it off the GPS Unit and immediately smelt burning fumes from the device. I let it cool off for about 20minutes and then tried to Power it back on, without any USB connection. NOTHING! Plugged in the USB to the Dashcam without the GPS Unit and only received a Blue indicator, no display or start up noise. When I got to work, I plugged it into my laptop with a USB cable and the computer was not able to recognize the device or read the microSD from it and only the Blue indicator stayed on. Upon unplugging it, the Blue indicator will turn off. I have tried to hold power button for a long period of time and was not able to get a screen up...
I have the hard wire kit, purchased from the same vendor of the camera on eBay.
erkme73
9 x mini 0806's
Have you tried holding the power button for 20+ seconds?
I
itskv
Yes I have held it for about 1min as well. Nothing
Rayman.Chan
Shenzhen
China
mini0806, mini0806S, mini0903/0905, mini0906, mini0808
try hold UP button an connect to windows, will you got a new hardwire installed?
if yes, try DirectUSB
if no, I think the PWM IC damaged, you need a free replacement.
I
itskv
I will try that.
I have contacted the seller and they requested that I send this item back to China for a replacement. I think that is not very cost effective for a replacement as shipping there is easily $30USD from USPS from the USA without insurance or other options. And I purchased from a USA warehouse. I am also waiting for their response for a refund.
jokiin
Too many ¯\_(ツ)_/¯
you can't send through the post either, they won't take cameras to China so need to use an express company
I
itskv
I tried this method and my computer and laptop both say USB Device Not Recognized.
DirectUSB will not connect as well.
CheckYourLights
Front&Rear-SH800/ Front 2nd Vico-Opia 2
I think you need the driver for your PC called Ambarella Evaluation Board
I
itskv
I have had success recognizing this device before this incident.
I purchase this from eBay: bruce_lee_dt and the seller would not offer partial refund. I would take at least 50% of the cost back since shipping this to China would bring my camera cost to nearly $200 USD. If I can just recover at least 50% of the camera that would be great.
DO NOT BUY FROM bruce_lee_dt!
CheckYourLights
I
itskv
Rayman,
Are you highlighting the parts that possibly malfunctioned?
I have tried the recover bricked camera method with the OTG adapter and USB Male to Male and was not about to "recover". The blue LED only lights up once USB is connected, once removed, it turns off. Holding power button for 20+ secs will not do anything.
I
itskv
Well I guess one of the components are dead.
Possible to replace?
Rayman.Chan
Shenzhen
China
yes it is, if the input voltage/current is too high, the IC maybe damaged.
it is RT8059GJ5 or substitute LC3406.
almost half return cameras for repairing is on this fault.
if you have the skill to replace it it will be much easier.
erkme73
9 x mini 0806's
This would lend credibility to the theory that the charger being used to power the camera failed, and allowed unregulated (higher) voltage to get to the 0806. I have zero confidence in the supplied charger. I don't know who makes the hardwired kit you've been using, but if it's still installed, and there's a quick/dirty way to measure its output voltage, you'd have a pretty strong case against the vendor/supplier - if the voltage is higher than 5.2VDC.
jokiin
Too many ¯\_(ツ)_/¯
best they'd probably do would be replace the power supply
erkme73
9 x mini 0806's
Ultimately, that's probably true. But since the PS and 0806 came from the same supplier, if they refuse to accept complete responsibility, I'd get Paypal/CC-issuer involved and demand a charge back for a defective product... Just ideas.
madmax
People! Do not buy on Ebay from bruce_lee_dt.
The seller is dishonest, selling broken camera and refuse to accept returns
My 806 died after 10 days, the seller did not refunded, did not responded.
Avoid bruce_lee_dt
Rayman.Chan
Shenzhen
China
yes we have stoped any business with that vendor. Current we developed ourself car charger and included in new mini 0806 and nanoQ 0903.
cost increased but it is more safe for our product.
