The collector
- Jun 17, 2015
- United Kingdom
I replaced my battery yesterday due to ad hoc recording issues. The previous threads on this site made it possible, I thought I would post a couple of photos which show the unit opened up.
This one shows the unit part dismantled before the circuit boards are separated. You can see four screws, the spring and the small ball bearing that sits on it to create the clicking effect when the outer ring is turned. To remove the outer ring in the first place there are two key areas to focus on and these are shown at the 12 and 6 o' clock position on the ring.
The next picture shows the boards separated along with the battery. To separate the boards I used a flat piece of plastic the size of a small screw driver. I inserted it between the slot where the pins are located and twisted it gently along each of the three sets of pins. This pushed them apart rather than pulling which could damage the boards.
The unit is working well at this time but too early to say if the problem is solved. There are many other threads on here with more pictures, I have just posted a couple which may be of help when searching.
