OneCheapDrunk
- Sep 12, 2015
- Queensland, Australia
- Australia
- mini 0803, mini 0806
Hello,
I've got a working mini 0806 with firmware: "0806 GD 20150511 V1.0"
This unit works without any problem with a Samsung 16GB micro SDHC card.
If I install my new Samsung EVO 128GB micro SDHC XC card, then power the unit on, it begins to record, then appears to freeze. No error, no further recording, won't switch off.
If I remove the card in this frozen state, I sometimes get an error "card too slow!" or similar. If I get that error, I can then power off the cam.
If I don't get that error, the unit has completely locked up and I have to wait for the battery to run flat.
Has anyone had any issues with this type of card?
Thank you.
- This card has been formatted as 128GB exFat (both under Windows 8.1 and inside the camera) - same fault.
- Re-created MBR - same fault. Tried as GPT and MSDOS types - using gparted (Kubuntu) and then Windows disk manager - same fault.
- Created 64GB FAT32 partition - same fault.
Thank you.
