Nigel
- Jul 7, 2014
- Wales
- United Kingdom
- Gitup F1+G3ꞈꞈꞈꞈꞈ Viofo A229ꞈꞈꞈꞈꞈ Blueskysea B4K
This has got a bit complicated!Perhaps Nigel will chime in here to clarify but I believe what he was talking about is that the highest resolutions possible with the mini 0806 - 2304x1296p @ 30fps and 2560 x 1080 do not translate in those resolutions to most common sized computer monitors and media players at full screen and therefore the image gets re-sampled (down-sampled) when you attempt to view the video. Depending on the re-sampling method and resizing ratio a nice clear high resolution image has the potential to not only not be improved but it can even end up looking rather poor. A crude metaphor might be to imagine trying to squeeze a chessboard down to a smaller size and now some of its squares (pixels) have nowhere to go. You would need a 30 inch monitor capable of displaying 1600p to view 2304x1296p video at pixel for pixel reproduction.
If you want the best licence plate readability from the 0806 then it is essential to use the 2560x1080 21:9 resolution since that resolution will place significantly more pixels on the license plate than any of the others; you then need to view it using a method which allows you to see all those pixels, ideally full screen on a monitor of the same resolution. That is actually one of the standard monitor sizes but most people have a 16:9 aspect ratio monitor so to see all the pixels they will need to zoom in unless they have a 4K monitor.
If you set the 0806 at 1920 x 1080 16:9 to match the Mobius resolution then it has a hard time even matching the licence plate readability of an 0801 due to it having a significantly wider angle lens thus less pixels per license plate; how it compares to the Mobius will depend on which lens the Mobius has but the Mobius is likely to win whichever. Switch over to 2560 x 1080 and the 0806 should easily win as long as the WDR doesn't cause issues, the Mobius can't manage such a high resolution.
If you are going to compare two cameras then I think you should use both cameras set to their best settings, and then compare them by examining the results at full resolution. Unfortunately the images we see above from the 0806 have been resized down to just 810 pixels high which is definitely not a fair comparison, as far as the comparison between cameras is concerned you might as well post them at 81 pixels high where you wouldn't even be able to see where the license plates are!
Maybe the problem with the resized images is due to this forum resizing them on upload?
I upload mine elsewhere and then link them in with the "Image" button and the result is full resolution mini 0806 images:
