Dears,
I am new to the dashcam experience but I did some reasonable amount of searching, however I did not come across a problem similar to mine. Thus this thread.
The issue: the Mini 0906 will not go into parking guard mode - keeps recording with FHD resolution @ 30 fps.
The setup:
- the camera is set to never turn off (auto power off is deactivated)
- basic recording is set to 1080p @ 30 fps for both front and rear cameras
- parking guard is set to continuous timelapse (but I also tried with motion detection etc.)
- hardwire kit I use is this: https://www.aliexpress.com/item/Uni...ter-Cable-for-Mini-0906-Dash/32835298362.html
- I checked many times with a voltage meter that:
a) red (power) wire gets constant 12V (and over)
b) yellow (Acc) gets 12V after ignition and goes to between 0V and 0,05V when the engine is off
- power cable is connected to the GPS base
I also checked with the rear camera disconnected - no difference.
I also tried disconnecting the ACC line to make sure it's getting absolute 0 volts - no luck either.
The hardwire kit is set to 12V as low voltage protection cut off.
The conclusion that comes to my mind is that the hardwire kit is not generating that special signal - do you guys know any way to actually check for this signal on the USB cable (which pins should I measure)?
Thanks for any suggestions.
Mike
The setup:
Mike
