This one isn't 3m adhesive but mounts on the rearview mirror and allows you to take it off whenever you want, but it takes up to 10 minutes to mount/dismount because of the rubber shim. You can adjust it so the camera sits right behind the rearview mirror but it will never be as close to the windshield as the 3m mount so the view distance will be further back. The tension holds well against vibration, it's been 1 week and the mount hasn't moved at all. Of the 5 mount attachments it comes with, 1 will just barely fit so it is not quick release but you get 4 other mounts including a screw on mount if you ever get a different dash cam or action cam.
