Mini0807 samples with parking guard function using OBD are ok now
Thank you.
At 31:30 the lens could be turned easily with your fingers, but at 33:40 you need pliers. Can you explain what changed in between?
I also damage the screw thread on the lens I use some pliers. Using needle-nose pliers not make much sense.
Important, you need a good clean glue around the lens !
I record this video Xiaomi Yi 2 camera, 41 Mpbs and 2K ( 8 gb Upload ) I hope you will like it.
@BELLA WONG
Do you have a link for the part you used? The metal base?
Thanks!
I have Viofo A119 and I'm getting a few corrupt files and some files wont play.
Anyone got any idea what the problem could be,
I have formatted the 64gb Kingston class 10 card and still having the same problem and sometimes it wont loop.
Thanks in advance
