The choice between a mirror dash cam and a conventional windshield-mounted dash cam comes up fairly often. Both serve the same basic purpose, but the two formats differ in installation, visibility, and how well they fit different vehicles and driving habits.
Here’s a practical comparison based on how each type is designed and where each one tends to make the most sense.
How They Differ
A regular dash cam is a compact unit mounted to the windshield or dashboard, recording through the front windshield. Many models also support a separate rear camera, while any built-in display is typically integrated into the camera itself. This is the more established format, with a wide range of products and mounting options.
A mirror dash cam, sometimes called a smart rearview mirror or digital rearview mirror, attaches to or replaces the existing rearview mirror. Its mirror surface also functions as a display, showing a live feed from the rear camera. This makes it more than simply a dash cam in a different shape, it changes how the driver views the rear of the vehicle.
Advantages of a Mirror Dash Cam
Better Rear Visibility
A conventional rearview mirror can only show what is visible through the rear window. In SUVs, pickups, minivans, and vehicles carrying passengers or cargo, the view can easily be blocked by headrests, luggage, or window tint.
With a mirror dash cam, the rear camera is mounted toward the back of the vehicle and provides a digital view directly on the mirror display. Many models offer a field of view around 140 degrees or wider, giving the driver a broader view of what is behind the vehicle.
Cleaner Cabin Integration
Because the display occupies the existing rearview mirror position, there is no separate screen mounted on the windshield and no additional device taking up dashboard space.
The rear camera cable still needs to be routed through the headliner or trim, so installation generally takes more time than a basic front dash cam. Once installed, however, the setup can look relatively integrated.
Less Nighttime Glare
Traditional mirrors can reflect headlights from vehicles behind you directly toward the driver. A digital rear view displays a camera image instead, allowing the image brightness to be adjusted or processed rather than relying on reflected light.
Advantages of a Regular Dash Cam
Simpler Installation and Greater Portability
For a basic setup without parking mode, a windshield-mounted dash cam can often be installed in about 20 minutes: attach the mount, connect the power cable, route the rear camera cable if needed, and you're ready to go.
This is particularly useful for drivers who regularly rent vehicles, switch between cars, or simply prefer a setup that can be removed easily.
More Flexible Mounting
A regular dash cam can be positioned at different heights and angles on the windshield. Many drivers mount it high and behind the rearview mirror to keep it out of the main field of view.
A mirror dash cam is tied to the position of the factory rearview mirror. While the camera itself may offer some adjustment, the available mounting position can be more limited depending on the vehicle.
More Choices at Different Price Points
Regular dash cams are available in a wide range of designs and price points, from compact models with minimal displays to larger touchscreen units with features such as GPS, cloud connectivity, and different storage options.
Mirror dash cams generally require a larger display, housing, and longer rear-camera cable, which can increase the overall hardware cost.
Placement, Obstruction, and Legal Considerations
Mounting position is worth considering beyond aesthetics. Windshield-mounted devices should not obstruct the driver's forward view, and requirements can vary by state and jurisdiction.
A compact regular dash cam mounted high behind the rearview mirror can help minimize obstruction. A mirror dash cam does not require an additional device to be placed on the windshield itself, although local regulations should still be checked before installation.
Who Should Choose What?
A mirror dash cam may be a better fit if you:
Wolfbox currently offers both types of dash cams. Our mirror dash cams include the G900 Pro and the three-channel G900 TriPro. If you’re interested, you can check out reviews of these models in our subforum.
We also have a regular windshield-mounted dash cam coming soon. If you’re planning to get a dash cam, which type would you choose for your vehicle, and why?
How They Differ
- Drive an SUV, pickup truck, minivan, or another vehicle with limited rear visibility.
- Frequently carry passengers or cargo that can block the rear window.
- Deal with glare from headlights behind you at night.
- Prefer a more integrated setup.
- Plan to keep the system installed in one vehicle long-term.
- Drive a sedan or coupe with a clear rear view.
- Want quick installation and easy vehicle-to-vehicle portability.
- Are primarily concerned with front-facing recording and don't need a digital rear display.
- Want the widest selection of form factors and features.
- Regularly rent or switch between vehicles.
