sharpharp
- May 9, 2015
- United Kingdom
Hi all,
Got the Mobius a few months back and have it setup in the car on Mode 1 with auto start record when car starts.
Also, had the settings on Auto Loop when card full.
It was working fine for the first few months (flashing green and yellow LED, but now when checking, almost 3/5 journeys see a solid yellow LED and then red led on solid as well. This means that the unit is in standby... but why?
I've reset the Mobius, checked latest firmware, tried several memory cards, but the issue is still intermittent.
Can anyone help? I need something reliable and this Mobius is well flakey.
Thanks,
P.S. I am using a USB 3m extension cable in the car, could this be the issue? Just read a thread saying it has to be a USB "Charging" cable, but I assumed all usb to usb micro were the same? This is the cable I use: https://www.ebay.co.uk/itm/400844006733I also use the standard battery in mine. Shall I change it to a supercapacitor? If so, do you still need to use a proper Mobius charging usb cable for a Mobius with a supercapacitor in?
Thanks,
