Did a test too today, plugget into power via the USB extension cable in the car the cam stopped to record after the 3.5 Gb empty gap filled up.
But i was expecting this to happen so i had my innovv pointed at the mobius to dokument wierd flashing, but after the 3 Gb filled up all lights on cam whent out, so when i reached my destination i stopped my car and put the innovv and mobius in my pocket.
A while later i discovered the mobius was still running as it was hot in my pocket, cant remember witch color light was on it when i took it out of pocket.
Again a while later i plugged the mobius into the USB cable Again for my return trip, and i allso put the innovv on it, i managed to catch the irregular red flashing of the rear LED and i allso discovered the LED on the side was flashing in 2 colors.
When i got home the mobius would not be found by my computer, or rather it would but only as a drive letter,and with no indication of what was on that drive, so i had to put the SD Card into a reader i discovered new Things. ( in reader Card and content on it was resolved normally )
1. for some reason the recordings from today ( 18-03-2014 ) was not on the Card, and the recordings the camera made later on when it found itself Again was labled 02-01-2013.
2. The camera had made a syscfg file on the Card dated 02-01-2013, tontent of said cfg as follow.
Date time=[2013/01/02-02:41:16];date time setting,format yyyy/mm/dd hh:mm:ss
Video Mode 1 resolution=[0];Movie resolution setting,0:1080p(Large AOV),1:1080p(Small AOV),2:720p(Large AOV),3:720p(Small AOV)
Video Mode 1 Frame Rate=[2];Movie frame rate setting,1:60fps (only for 720p small AOV), 2:30fps
Video Mode 2 resolution=[0];Movie resolution setting,0:1080p(Large AOV),1:1080p(Small AOV),2:720p(Large AOV),3:720p(Small AOV)
Video Mode 2 Frame Rate=[2];Movie frame rate setting,1:60fps (only for 720p small AOV), 2:30fps
Photo Mode Capture Size=[0];set photo size,0:2304x1536,1:1920x1080,2:1280x720
Set Time Lapse Shooting=[0],0
ff,1:0.25s,2:0.5s,3:1s,4:2s,5:5s,6:10s,7:30s,8:60s
Photo Flip=[0];set Photo rotate,0
ff,1:flip on
Movie cycle time=[1];movie cycle time,0:3 minutes,1:5 minutes,2:10 minutes,3:15 minutes,4:max to 4G byte,
Movie Loop Recording=[1];set loop recording on or off,0
ff,1
n,
Time stamp=[1];set date/time stamp on or off,0
ff,1
n,
Movie sound=[0];set movie sound,0:mute,1
n,
Movie Flip=[0];set movie rotate,0:both off,1:mode 1 on and mode 2 off,2:mode 1 off and mode 2 on,3:both on,
Movie quality=[0];set movie quality,set movie data rate,0:Super,1:Standard,2:Low,
Movie high dynamic range=[1];set movie high dynamic range,0
ff,1
n,2:Enhanced Brightness.
Power on=[1];set system power on time,0:delay,1:fast
Power off=[0];set system auto power off time when system pending,0
ff,1:30 seconds,2:1 minutes,3:2 minutes,
Auto Record with External Power=[1];set connect with power to start video recording automatically,0
ff,1
n,
One Power Button to Auto Record=[1];set press power key to start video recording automatically,0
ff,1
n,
Auto Off with External Power disconnected=[1],0:Immediately,1:delay 10s;2:record to low battery power off,
LED=[1];set LED flicker when recording,0
ff,1
n,
Charge from USB Host=[0]; when connecting with USB host, charge camera or not,0
n,1
ff
Lens option =[1];select lens,0:lens A,1:lens B
Light frequency =[0];set light source frequency,0:50 HZ,1:60 HZ
TV out=[0];set Tv out,0:NTSC,1
AL,
TV Display Ratio=[0];set display ratio,0:4*3,1:16*9
Motion Detect=[0];set motion detect,0
ff,1
n
Motion Detect Timeout=[2];set motion detect timeout,0:5s,1:15s,2:30s,3:60s
Motion Detect Sensitivity=[0];set motion detect Sensitivity,0:high,1:nomal,2:low
White Balance=[0];Set White Balance,0:Auto,1:Sunny,2:Cloudy,3:Tungsten,4:Fluorescent,5:Custom WB1,6:Custom WB2,7:Custom WB3
Sunny(5000-6500K) used for sunny with clear sky(Rgain=301,Ggain=256,Bgain=368);
Cloudy(9000-10000K) used for shade or heavily overcast sky(Rgain=301,Ggain=256,Bgain=384);
Tungsten(2500-3500K) used for Tungsten bulb (or called Incandescent light)(Rgain=184,Ggain=256,Bgain=711);
Fluorescent(4000-5000K) used for fluorescent lamps(Rgain=333,Ggain=256,Bgain=525);
Customized White Balance 1 Red Gain=[256],Green Gain=[256],Blue Gain=[256];
Customized White Balance 2 Red Gain=[256],Green Gain=[256],Blue Gain=[256];
Customized White Balance 3 Red Gain=[256],Green Gain=[256],Blue Gain=[256];
Set red ,green,blue gain,256 is 1x gain,value from 100 to 999;
Color Effect=[0];Set Color Effect,0:Standard,1:Mono,2:Sepia,3:Cool,4:Cooler,5:Warm,6:Warmer,7:Vivid
Exposure Value= [0] ;Exposure compensation,values from -128 to +128,In 1 increments,default value is 0,
Contrast= [0] ;Set Contrast,values from -128 to +128,In 1 increments,default value is 0,
Saturation= [0] ;Set Image Saturation,values from -128 to +128,In 1 increments,default value is 0,
Sharpness= [0] ;Set Image Sharpness,values from -128 to +128,In 1 increments,default value is 0,
{TLCAM MOV:TLCAM Mobius ActionCam 2014/02/14 v1.17}
{LDTLCAM,v003}
The first time the cam freaked out this way i did not see a CFG file on my Sd Card. ( i have never seen that before )
Stay tuned for a video recorded today, and allso a second attempt to replicate the error witch i will perform on my computer table.
But first i have to charge my innovv c1 up and find a power source to power the mobius on, i am interested in how long it take from the Card fill up and the LEDs go out, and untill the leds come back online and LED flashing resume to normal recording flashing.
