reverend
- Apr 22, 2014
- United Kingdom
- Too many
A few quick comparisons here for you today - I've not had chance to grab all the screenshots yet but here are a few side by side comparison videos:
Firmware:
Mobius - 2.25
Panorama X2 - Test Firmware 1.01.04
Mini 0805 - 20141101
Mini 0806 - Test Firmware 141128
Resolution:
Mobius - 1920x1080 30fps - low light mode (FOV changes and is named in the video title)
Panorama X2 - 1920x1080 30fps
Mini 0805 - 2560x1080 30fps
Mini 0806 - 2560x1080 30fps
Day:
Night:
Raw clips:
0805 Day - https://mega.co.nz/#!VYhlxBRZ!2en5cSOT1VMHSGUAqElNk6KV1Av-s_qoMiIQeFaKCSM
0805 Day - https://mega.co.nz/#!YYZBCRAS!coZIddph2-6bwQ9CAuZNcWRMb63YAkFbs7dWpVhzia0
0806 Night - https://mega.co.nz/#!0AxURZbI!TLz_i6HaV9o8Dsvc9-CD6zvuILdmDshu2tBkGt5UKxI
X2 Day - https://mega.co.nz/#!hVRGwapK!ZbxLvhAQGe4NCUxZ8xn3MkwsvFZ9yV6PWDuoCH1xYvw
X2 Night - https://mega.co.nz/#!0NpDFLKZ!lDuLRVuMrh33k6zGMaODJv4pmWz5MxW0-Ybye4GbPgk
Mobius Day - https://mega.co.nz/#!pQw2TBjQ!oNxz_6WTUvf2zNZIIYTh8_FSkm7RsByPGO55NQH5ssQ
Mobius Day - https://mega.co.nz/#!0U5BBCqT!OO0PDtoNzEdlVsKt4NAD41vRAHkAJCrKPjgUss9WLVA
Mobius Night - https://mega.co.nz/#!UNQ1XYwa!d8rBX7D-GZvUdThQoko6zYYQkcPqufWYK7edINhe_DI
Overview:
You can see that the X2 has the widest dynamic range and keeps up a pretty constant brightness in all scenarios where the other two can get a bit dark at times in the daytime. In terms of reading numberplates the Mobius is probably the best one out of the lot in the daytime - for some reason the Novatek cameras do seem to be very good at that, albeit you end up with a darker image. This is being worked on currently on the Panorama X2 firmware and a new version is due this year which should improve this quite significantly as well as the oversaturation / clipping problems in the daytime. Version 1.01.02 was much brighter at night time but had a green cast to the video, in 1.01.04 they've turned this down a lot but you can see still there's a slight green hue.
What isn't so obvious from the videos above is that the Mobius and Mini (to a lesser extent) seems to lose resolution at night time which isn't shown in these videos. This may be something to do with the Novatek CPU?
If you download the raw clips and watch them you will see what I mean.
Bearing in mind the Mobius A lens isn't as good at night as the B lens which has been shown by @niko in the past, I think that FW 2.25 with the low light setting is doing a great job and at some point I'm going to try the B lens up against these two and see how things look then as the AR0330 does have a dynamic range advantage over the OV4689 in none HDR modes.
It's quite interesting that the Mini 0805 has a similar FOV (field of view) to the Mobius A lens in narrow mode - you can see that the X2 is quite a bit larger so it's capturing a wider scene, although this means that things like numberplates are smaller and harder to read.
I think you'd be happy with any of these cameras as they all do a good job - the Mini cameras have a battery and so aren't suitable for 24x7 parking modes like the Mobius capacitor version and X2 and then the X2 has the best motion detection in parking mode of any of them (and pretty much anything on the market right now). With the Mobius you'd probably just leave it recording 24x7 in conjunction with a BDP solution.
I need to also get an 0805 vs 0806 test done at some point (when I can work out where to mount the other one) as the 0806 is better in both day and night situations from what footage I've watched, but it is the higher end version with a better lens and hardware design.
Firmware:
Mobius - 2.25
Resolution:
Day:
Night:
Raw clips:
Overview:
