You'll find verified vendors in this post - https://dashcamtalk.com/forum/threa...ts-here-read-posts-1-8-first.4232/#post-49835
You can change your battery to a supercapacitor which can withstand the heat much better.
Banggood has all the Mobius parts:
$5.99 820mAh battery: $4.58 Super Caps:
Hi All.
Does the 820mah battery can be installed in the Mobius1 action camera? im asking because i saw this in rcgroups forum:
Newer cameras are designed to use an 820mAh LiPo (803132). Newer models are date-stamped with 2014-08-19 (or later) on the circuit board under the lens module cable
i bought the Mobius 1 at the end of 2013, does it mean i can't install 820mah battery?
thanks.
Hi All.
thanks.
