joe384
- Aug 29, 2019
- Essex
- United Kingdom
- Viofo A139 3CH, A139 2CH, Mobius w/ Varifocal Zoom
By using the variable focus capability you can adjust the position of the rear element to compensate for what would otherwise be a fixed distance on a traditional camera, although you might lose (or gain) some of the focal range of the lens. Thus you just screw it into the housing as far as it will go instead of having to screw it in and out to achieve focus. For this reason you want the case closed when you attach the varifocal lens to a Mobius.
I actually found a few posts by you and tony where tony had to modify the case and also you mentioned you had swapped in a longer lens holder in your mobius. But like you say, I don't need to worry about any of that, just screw it on with case together.
I will check out the link for the uv bonding, that may come in handy at some point.
