country_hick
- Dec 10, 2014
- United States
If the Mobius 2 is not exactly what you wanted perhaps the Mobius Mini will be more to your liking.
This is NOT recommended for dash cam use. It has a 30 minute battery life. There is no supercapacitor option.
A support thread exists here. --> http://www.rcgroups.com/forums/showthread.php?t=2697022&pp=100
Tom Frank
United States, MA, Walpole
Joined Dec 2003
New Product
Mobius Mini Sneak Peek
The Mobius family is expanding again! This pre-release info gives a sneak peek at the new Mobius Mini... a cross between the M2 and the #16 keychain camera!
The sale price from the source is $69.
The Mini brings 1080p-60fps video (as well as 720-120 and WVGA-240) in a Mobius form factor with a size much smaller... close to the #16 size. The weight is nominally only 27 gms.
A short native sample clip with the pre-release FW can be downloaded or streamed from here. --> http://www.mytempfiles.info/mobius2/fw/Mini Pre-release Sample.mp4
Specifications:
Internal lipo battery: 300mah. It can record over 30 minutes for 1080p 60fps.
Power Input: standard USB DC5V, with over voltage protection (5.6V-25V)
Angle of View:FOV 110°Wide angle but with less distortion, minimum fisheyes distortion, almost same FOV as Mobius lense A.
Video:
1920 x 1440 1080P 30fps, 1080P 60fps, 720P 120fps, VGA 240fps
H.264 AVC High Profile, MP4
Audio: aac,
Photo:2688*1512; 1600*1200;1920*1080;1280*960
Time Lapse photo supported
JPEG
Mode switches: Video Mode 1, Video Mode 2, Photo Mode, you can customize each mode to suit your application.
TV out: PAL/NTSC
Low latency of composite video out, less 60ms 1080p 60fps, less 40ms 720p 60fps
Interface:Mini 10Pin USB(USB2.0 Highspeed)
Memory: support Micro-SD memory card (not included in the package). Suggest Class 6 or above. 64GB card supported.
LED indicator light: Red, Yellow, Blue, Green
Outer Dimensions: approx 54.5mm(L)*29mm(W)*14mm(H)
Net weight: approx 27 grams only with battery included!
Specifications:
Video:
Audio: aac,
JPEG
TV out: PAL/NTSC
Mobius Mini Function Set(subject to possible revision at release)
Specifications:
Video:
Audio: aac,
JPEG
TV out: PAL/NTSC
Basic Functions
· Sync Date/Time with PC
· Display: Date Only, Date and Time, Off
· Date Format: YY/MM/DD, MM/DD/YY, DD/MM/YY
· Recording Indicator: ON, OFF
· Rotate Image: 180 deg., NO
· Artificial Light Frequency: 50 Hz, 60 Hz
· TV Video Out Display Mode: NTSC, PAL
· Power-Off Standby: Off, 30 sec.,1 min., 3 Min., 5 Min.
· Auto-Record with External Power: Off, On
Video Functions
· Audio Sound: On, Off
· Motion detect: On, Off
· Image Stabilization: On, Off
· Loop recording: On, Off
· External Microphone: Enable, Disable
· On Screen Display (OSD - in Video Out Mode Only):
· View/Delete recorded images, change config settings, view system info.
· Two Video Modes - Set Frame Resolution and Frame Rate:
· 1440x1080@30fps, 1920x1080@60/30 fps, 1280x720@ 120/60/30 fps, 848x480@240 fps
· Video Quality (approx. ave. data rate): Normal (16 Mbps), Fine (32 MBps,) Super Fine (44 Mbps)
· Video Clip Length: 1 min., 3 min., 5 min., 10 min., 15 min., Max. (4GB FAT 32 limit)
Photo Functions
· Photo Frame Size: 2304x1728, 2048x1536, 1600x1200, 1920x1080, 1280x960
· Image Quality (JPEG): Normal, Fine, Super Fine (1.8 MB)
· Time-lapse Photos: Off, 3 sec., 5 sec., 10 sec., 30 sec., 1 min.
· Time-lapse Duration (auto-stop): Unlimited, 5 min., 10 min., 15 min., 20 min. 30 min., 60 min.
· Photo Burst (rapid images): Off, 3 photos, 5 photos, 10 photos
· Shutter Delay: Off, 2 sec. delay, 10 sec. delay, Photo - 3 sec delay - photo
· View OSD: Off, On
Advanced Image Functions
Exposure: -6EV to +6 EV, in 1 EV steps
White Balance: Auto, Daylight, Cloudy, Tungsten, Fluorescent
Metering: Multi, Center weighted, Center Spot
Tom Frank
Joined Dec 2003
New Product
Specifications:
Video:
Audio: aac,
JPEG
TV out: PAL/NTSC
Specifications:
Video:
Audio: aac,
JPEG
TV out: PAL/NTSC
Specifications:
Video:
Audio: aac,
JPEG
TV out: PAL/NTSC
Basic Functions
Video Functions
Photo Functions
· View OSD: Off, On
