Bluenose
- Dec 29, 2014
- United Kingdom
- Nextbase 622GW
Earlier I tacked the following to the older 'Problems with my X2' thread but I'm not sure it will have been seen as it is quite an old thread now. I therefore decided to start a new one.
HELP!!! I have inserted the cards and have told the system to update, I have now been looking at the same screen for more than 10minutes. The screen says 'Updating Firmware' 'Do not turn the power off'
The green bar that goes across the screen seems to be stuck about 1mm from the end.
Is it safe to turn it off and to try again?
EDIT: I had no choice but to turn it off, it had been 'updating' for more than 20 minutes and it was still jammed as mentioned above. When I tried to turn the unit on again it is now not working at all, the screen is totally blank and nothing happens when I touch the screen.
Any thoughts anyone?
Also,
Would it be at all possible for someone who currently has a 'trouble free' Panorama X2 to list their settings please.
I thought that it might be helpful if I could set mine up the same as someone for whom things are going well.
Many thanks
Also,
Many thanks
