Motion sensing while hardwired - how good is it?
Can this be done while a recording is in progress?
I normally stop recording when entering the app, but the camera is capable of transferring files while recording, it has an http server that you can access with a web browser or otherwise, get a file list, and download files while recording. It also has a "station mode" which lets it connect direct to your home network if you are parked within reception range, instead of you having to connect to the cameras network.
A lead acid battery is destroyed by prolonged periods of low voltage when sulphation occurs.
Let's have a small 44Ah battery with a default charge of 75% ... 33Ah. The camera draws about 0.5A, in 12 hours it draws 6Ah.
33-6= 27 Ah. That's 61% of capacity. If it is driven daily and the charging mode is traditional everything is fine.
The problem is charging a modern car controlled by the car control unit. There it easily happens that even after a long drive you park and the lead acid battery has 12.2 V ... which is 50% of capacity.
