BobT36
I have a 622GW and drive a 2012 Honda Jazz/Fit. Where would you advise mounting the dash cam?
I'm well aware that the area immediately in-front of the driver (essentially to the right of the rear-view mirror) is off-limits, including 40mm+ into the wiped area. (Is this the mount, or the visible obstruction, based on my eyesight angle?)
Bear in mind that I'll be wanting to use it as a reversing camera (since I have a rear window cam), so sticking it straight behind the mirror would be useless as I won't be able to see it.
A lot of the features involve interacting with the cam, so a bit silly if the only usable positions are over at the passenger sides or behind the rear view..
I was thinking slightly above the rear view mirror? (even if it has to go over the frit) using the adhesive mount. It's a bit arsey due to the length of the lens.
Any other ideas? (where I'll still be able to see / press the screen on the cam).
