Hello guys, forgive my first post, i've used this site many times for useful information. But now I need a little bit more.
I've just tried installing my first dash cam, a chinese model from Amazon. It works great using the cigarette lighter, so naturally my next step was to get this installed neater, with a battery saving device installed in the front of the car.
I believed I installed the multi safer correctly, I found a ground point for the black wire, then used add-a-fuse piggy back wires, red-onto the wiper motor, and yellow-onto the horn.
I get a constant led onto the multi safer unit, but when I plug the dash cam cigarette lighter into the female part of the multi safer, the led on the dash cam adaptor does not light, and as expected there is no power to the dash cam.
I have also checked by using a different adaptor (a cigarette-to-x2 USB slot) that also has an led indicator, which does not light up either.
I'm sure I installed the multi safer correctly, but here I have this problem.
Any thoughts?
Any thoughts?
