Welcome Ag8 to the forum.My car doesn't have a cigarette lighter plug, only USB-C connection. Are there dash cams that come with USB-C only cable?
Thank you. Will follow your advice.Welcome Ag8 to the forum.
I know of a few Dashcam that will work directly from the UBB -C port.
Ideally load test your usb port or find the specifications of what is capable of delivering. Eg 5V @2Amps for example.
Depending on what you discover will help you with which dash cams should work.
Viofo cameras come with separate lighter socket chargers and cables, so you can discard the charger and just plug the cable in.I'm finding ut hsrd finding dash cams tthat have USB-C cable oj both ends connection. thry all come with a cigsareytw lighter plug.
Quite likely not to work with the older USB-C cameras, they fail to negotiate for power!You could buy your own USB-C to USB-C charging cable, at whatever length you need (3m, 4m, 5m etc).
Thank you, for the info. Need to look for the right cable as TonyM suggested, and check the V / Amp capacities to make sure they are compatible. The challenge is I don’t understand these things very well, only get the concept of them.Viofo cameras come with separate lighter socket chargers and cables, so you can discard the charger and just plug the cable in.
Some of them have USB-A at the charger end, you can use a C-A adaptor although that is not ideal. The new A329 has USB-C both ends.
Out of interest, what is the car?
Dashcams with USB-C power ports are going to work at 5V, and need a maximum of 2A. Since the cable will be fairly long, I suggest overrating it on the Amps to avoid too much voltage drop, and make sure that it is a charging cable.Need to look for the right cable as TonyM suggested, and check the V / Amp capacities to make sure they are compatible. The challenge is I don’t understand these things very well, only get the concept of them.
