The Cnet article I linked to has links in it to a lot more cams and more info. Cnet is trustworthy but they're not really camera experts so their reviews and thoughts need to be taken as such. The way I see it, tucking a standard WYZE in tight under a soffit or similar will work for awhile, and it's cheap enough to risk, easy to use, and one he!! of a lot better than nothing. Get one or two (or something similar like Ring or Arlo) and learn from them, then decide on what you really need after that. Doorbell cams work well up close and a lot of people have them now.
These 'simple and basic' cams aren't great or terribly secure but darn few regular criminals or vandals are going to try to attack them electronically because A- They probably won't notice them B- They aren't going to put that much effort into anything without a certain and valuable payoff C- They likely don't know how to do an electronic attack. The biggest risk is that they'll do a physical attack on the cam(s) if they can locate them. If they see more than one they'll likely reconsider if their apparent coverage area overlaps as then they will be seen by one cam or the other when they try to neutralize one meaning they're going to get caught.
Same as dashcams they can't prevent anything or guarantee you'll catch the bad guy(s) but they're a step in the right direction and they can serve as a deterrent.
