SawMaster
- Apr 10, 2015
- SC
- Numerous and ever-changing
That would be the best form-factor @kissmancz unless you want to mount towards one side. But it also limits you to cams with only that form-factor which may not give you the functions you wish for. Blackvue and Thinkware have never been very accepting of user or owner input; they build their cams only the way they want them to be. Many other cam manufacturers do seem to take suggestions better.
Nobody builds the cam you want, so I would suggest that you make a list of what you want from a dashcam with the most important at the top of the list then going down to less important. Compare your list to what is available, and at each step the suitable cams will be reduced. When you get down to one or two cams your best choice should be clear to you. This will not get you everything you want but it's as close as you can get.
Or you can wait for the cam you want, perhaps using something basic until that cam hits the market. The B1W makes a pretty good cam at a low price and with good value too. If your climate is cool enough the 70mai can also fill in until they make your cam. These are single-channel cams but better than nothing while you wait. Just don't expect to have all your wishes fulfilled any time soon- dashcam technology moves slowly and is always far behind the times compared to other electronic devices
