My review and test of the Vantrue E1 Pro
I was given the Vantrue E1 Pro dashcam to review, and I wasn't provided with any guidelines or instructions on what to include in my review. Everything you read here is based solely on my own opinions and experiences with the product. There is no text nor information I was instructed to include (or not).
I'll go over some major categories which are important to me in the use of a dash cam. Note: I am not a super pro user by any means (at least, not when it comes to dash cams). I think that my review compared to some of the other ones are likely less technical but considered from a more "average user" type of experience.
On screen navigation:
The Vantrue E1 Pro dashcam has a lot to offer, but I found the on-screen interface to be a bit overwhelming. When the screen is on, it’s cluttered with various icons and functions, which makes navigating through the options quite distracting and difficult to follow. It takes a while to get the hang of it, and I found myself fumbling around more often than I’d like, so I eventually gave up on trying to navigate and make changes on the device itself.
I think this may be due to having to awkwardly push the buttons to navigate on the screen (like the old school tech devices when I was much younger). On the other hand, the screen is so small that touchscreen navigation would've also been almost impossible for my fat fingers.
Therefore, control via the app is almost a necessity for easy navigation and settings changes.
Another issue I had was not being able to intuitively figure out what the dashcam side buttons do without having to read the manual. Usually, it's quite easy to figure out these things without needing to read the manual, but not the case here for me. However, once I did spend some time with the manual, I determined that the buttons are sensibly placed and oriented.
On the hardwire kit:
Unfortunately, I was not able to test the hardwire kit (and therefore, unable to test the parking function of the dashcam).
The first hardwire kit (and the second) did not deliver any power to the device. I even had my mechanic test the hardwire kits, and while it seemed that power was being delivered to the transformer unit, no power was transferred from the transformer component to the actual dashcam. This was a disappointing setback, as I was unable to use the hardwire kits for a consistent power supply. Essentially, what we determined was that the multimeter was able to detect voltage when directly connected to the car's fuse box on the driver's and passenger's side. We were able to pull 11-12v appropriately. Then, when the hardwire kit was connected to the fuse tap, and the multimeter to that, we read 0 voltage. This occurred with having the 3-wires connected appropriately (red to constant power, yellow to ACC, and then the last to ground). No power whatsoever.
To make sure it wasn't an issue with my car, the mechanic even tried his portable battery pack which we were able to test as delivering 12v of power when directly connected to his multimeter. When we connected the hardwire kit to his portable battery, again, we were unable to get any power.
I researched online and tried some solutions mentioned on reddit but it did not yield any results. We did read the manual to confirm that the mechanic was installing it correctly but to no avail.
I will say that the Vantrue team was very accommodating and shipped out a replacement (the second one) kit very quickly. Unfortunately, that too, did not work.
As an aside: I purchased a mini-USB to USB-connector online (random generic brand) to see if my old hardwire kit for my now almost 11-12 year old Mobius would work since the voltages were identical to the Vantrue kit. And it did! Vantrue has indicated that I should not be using the dashcam in this fashion when connected to my old hardwire kit, so I won't, but I just wanted to see if it was a car issue, a dashcam issue, or what now appears to be confirmed as a hardwire kit issue. Instead, I am powering the dashcam via the 12v power (cigarette lighter) from the car. It works perfectly with the supplied power.
On resolution and clarity:
I was quite disappointed to learn that none of the supported resolutions support 60 fps. I've been accustomed to 60 fps, even with my decade-plus old Mobius dashcam, albeit you did have to reduce the resolution to obtain 60 fps recording. This seems like a missed opportunity although I am sure there is most likely a technical or cost-reason associated with its exclusion.
That being said, the video quality for the Vantrue is sharp. There is a feature called "PlatePix" which enables easier reading of license plates. However, this comes at a cost of reducing the light exposure on the recording. However, this seems like a worthy trade off considering part of the reason we use dashcams is to capture license plates if something goes wrong.
I took this video (3840x210P at 30 FPS) on an overcast day with HDR on (and later off) and PlatePix permanently on. I intend on keeping PlatePix on permanently since I'd want to take advantage of the ability to get a better view on license plates. Firmware was updated to the most recent.
I did notice that the HDR would constantly attempt to recognize and readjust for changing conditions. I was visiting a friend and drove all the way to his place and decided to take some footage where he said there would be changing lighting conditions because of the hills and trees. For the first part of the daytime video (up to 6 min), HDR is on. After that, it's off.
You can clearly see that the HDR-on portion of the video is darker and the color/brightness levels are changing as HDR tries to adjust.
Note: both videos are uploaded to YT in MKV format.
<iframe width="420" height="315"
src="
</iframe>
Once HDR is turned off, the colors become more vibrant and the general brightness is increased. HDR off represents more of what I saw when driving and appears more accurate to me.
The nighttime drive was similar. I had HDR on until the 8 minute mark. At that point, I turned it off for a comparison. Unfortunately, I was not able to capture longer footage outside of this area before I needed to return to the airport. PlatePix remained on the entire time.
src="
</iframe>
Any starbursts or halos were not the camera's fault. They were mine. I had a little bit of condensation developing towards the bottom of the windshield and needed to use the wipers to take it off as the defogger function was not working well. Using the wipers introduced some moisture onto the glass towards the end of the video and it created some halos.
I am quite pleased with the STARVIS 2 sensor during its nighttime performance.
You can also have the dashcam stamp the GPS settings, speed, and time, if you choose.
Overall, I did find the video resolution to be fairly good, especially for the price. When compared to popular wedge-shaped competitors that are in the $179.99 (2k) - $289.99 (4k), the Vantrue E1 Pro delivers strong performance for a more cost effective price. Some people may strongly prefer the E1 Pro square shape which--if your windshield is not highly angular--can be hidden pretty well under the frits (as I had done with my prior dashcam). With an angular windshield, this is a bit more challenging. However, the pricing for this dashcam at MSRP, especially when it includes the STARVIS 2 sensor, is great! And, if you couple the MSRP with the 10% coupon that's often found on the Vantrue homepage, this is an even more compelling deal for people that need only a front dash cam.
On mounting issues:
I experienced a fair bit of trouble mounting the E1 Pro to my windshield. I was surprised because despite the diminutive stature of the E1 Pro, the mounting process quickly became frustrating, especially when it came to finding the right angle. This is due to the dashcam’s square shape—while stylish and modern—made it difficult to position the camera in such a way that it didn’t capture the rearview mirror stem, the rear view mirror connector (to the windshield), and to also avoid the frit on the top. To top it off, I was trying to set up an mounted angle so that the lens of the dashcam peered out right under from the frit to create a more "stealth" look. Unfortunately, this was not possible. This is because if I attempted to do so, the steep angle of the windshield prevented the dashcam from being able to appropriately look down at the road versus up to the sky.
No matter what I tried, I was unsuccessful in this regard. If I moved it slightly lower, I encountered another issue: reflections. Due to the shape of the E1 Pro being more square, as opposed to the wedge-shaped dashcams (or even my trusty old Mobius that could be lined up right up against the glass) that allow the lens to be positioned straight up against the glass, having the lens further back meant I would get more reflection from the interior of the cabin. It is important to note that my windshield is not tinted.
Note: I also did not conduct the test with the polarizing filter. Therefore, the reflections seen towards the sides of the windshield may be resolved with the use of a CPL filter. I did not have a CPL filter included in my test unit, but am planning on getting on separately.
This isn't a knock against the E1 Pro, but against any dashcam shape that is not able to have its lens right up against the glass.
My solution? I ended up dropping the mounting location of the dashcam a bit further down from the top. I wasn't too happy about it, but it resolved the concern about not being able to properly capture the street versus the sky. In addition, I have a dash mat (also known as a "dash cover") (a fabric that goes on top of the entire dash) to help reduce reflections and to keep the dash of the car from being discolored by the sun.
As for included hardware: the dashcam comes with a secondary mount that you attach to the actual dashcam unit which then has VHB tape (double sided and it is already pre applied) which then gets applied to the electrostatic windshield sticker. Very easy to use and set up. The secondary mount piece also has a spot to plug in the USB C cable (which means you can either go into the mount or you can go into the dashcam directly).
On miscellaneous items:
I found the packaging of the Vantrue E1 Pro dashcam to be very well set up and had a premium feel to it. Everything was carefully laid out, packaged, and protected, which gave a great first impression of the product's quality and attention to detail. This is my first Vantrue product I have used and I recall being quite impressed when I first unboxed the dashcam. I very much appreciated how everything was put together so well--on the flip side, since everything was strategically and efficiently put together, I was unable to put everything back in the box for easy storage (LOL). It's always like that!
As for the initial boot-up sequence, I found the process to format the SD card quite confusing. Apparently, I ended up reformatting the video card after installing the most recent firmware, even though that was not my intention. I believe that when you go through the prompts once you boot the dashcam up again, it should easily take you back to the recording ("ready to go") screen directly rather than navigate the settings again. I think that's where I encountered confusion. Perhaps this is user error, but perhaps it could be simplified. I read a few different posts online about the firmware upgrade process with similar complaints. However, in reflecting the menu options I went through setting up the firmware update, I should've known better than to blindly accept reformatting the SD card. I thought it might've been part of the process, but should've realized that formatting and losing any saved video clips should not be part of any firmware update! My mistake on that end.
The dashcam does get quite warm to the touch. I was testing the dashcam mainly in temperatures from 55-65 degrees Fahrenheit (ambient outside temperature). Perhaps the inside temperature was closer to the 65 degree mark. Even a short 10-15 minute car ride made the dashcam unit quite warm, surprisingly. I am unsure how this would fare during the summer. Interestingly, I took a much longer drive on a different day where the dash cam did not get as hot as it did just a couple days ago. Surprising to say the least. I'll keep evaluating for any significant temperature variations on my end and if I see any, I'll post here.
I believe you can turn off the screen when driving per the user manual (on page 3). I forgot to test this myself. I think that having the screen off should also help bring the E1 Pro's temperature down. I'll need to check this out the next time I'm out on a drive to confirm.
On final reflections:
After all these considerations, including what appeared to be two defective hardwire kits, I am still very pleased with the E1 Pro. Although I received this unit for free to test, I would've purchased it anyway because it seems like a very straightforward replacement for my now decade-old Mobius action camera. I wanted an increase in night time performance (which the E1 Pro has), increased resolution (which the E1 Pro has), and an easy to use interface (which the E1 Pro has with app).
The biggest detractor in my opinion is video stabilization since it will be highly mount dependent (versus being able to have the dashcam completely attached to the windshield (wedge shaped dashcams can do this) and lack of 60 fps recording. Depending on the sturdiness of your mount, one may experience more bumpy playback video.
The best positives are the price, resolution, and STARVIS 2 sensor. Plus, the app makes navigating the dashcam very easy to use (make sure to disable any VPNs before trying to access the dashcam).
Next up for me: obtain the CPL polarizing filter and see if that increases performance (such as reducing the glare from the sides of the windshield) and obtaining a lens cover for when I need to remove the dashcam from the car.
Finally, big thanks to the Vantrue team for letting me try this out. Appreciate it, @Jeff_Vantrue!
Here are some pictures of contents of the actual box contents:
I appreciate the comparisons with HDR on and off. I agree with your assessment of distance from the windshield to the camera lens and picking up reflections from the inside of the window. I'm planning to get a polarizer lens as well. Overall, it's an impressive little camera with a great big image.
Thank you!
Yes, the reflections are definitely annoying because unlike my old Mobius, I can't bring the E1 Pro lens directly up to the windshield safely (or practically due to its shape). I ended up not even needing a polarizing filter for the Mobius because of how close I could get its lens to the windshield. I think I will pick one up for the E1 Pro since it does seem like it's necessary for angled windshields.
I did see a comment from Jeff at Vantrue indicating that the polarizing filter is included in new E1 Pro retail purchases although perhaps the test kits did not receive any (on the other hand, I was sent the hardwire kit for testing purposes which otherwise wouldn't come in the E1 Pro retail box).
I also have started to drive with the screen off (there's an auto-off timer in the settings) to help manage excess heat. Plus, I don't need the additional distraction when driving.
I'm now debating whether to keep PlatePix on or off. Dashcam video looks great during the day with it off and you can still pick up license plates easily in good weather conditions. Real test will continue to be at night and during inclement weather conditions. My other thing with not keeping PlatePix on is that once I apply the polarizer lens, it too will darken the image a little bit. Then, it may get too dark with two different items reducing brightness.
Hoping the polarizing filter increases perceived video playback quality compared to some of those other dashcams on the market.
I do expect the image will be a bit darker with both PlatePix turned on and a polarizer installed. One potential way to offset this is with the "exposure compensation" setting in the menu.
Good idea--I'll have to give this a go!
I was driving at sunset yesterday with the CPL fitted and PlatePix enabled on my E1 Pro. It did OK, but it did look darker than I want, so I removed the CPL for the remainder of my drive into the night.
I think cos PlatePix smashes the contrast and the CPL darkens it then it's just not gonna work with both.
It's honestly just Vantrue's image processing ways and marketing speak, PlatePix, like I found in my initial findings when it first came out on the nexus 4 pro. Nothing revolutionary but on the flip side, every little bit helps with plate capture.
The combination of PlatePix and the CPL was useful when I was driving towards the low sun, but the contrast was high so shadows were very dark. Because the CPL is more difficult to install and adjust than, say, the Viofo clip-on CPL, I think I will probably leave it off most of the time. I drove quite a bit at night so I want as much light as possible.
They could do better at explaining that in some scenarios, folks won't want PlatePix on because it just makes it too dark. Especially with CPL filter on
When enabling PlatePix in the App there is a warning that it will reduce the brightness.
Agreed, although as @Julian23 points out there is an on-screen warning when you enable PlatePix.
As a tester I'm happy to try various combinations of settings. The average customer might be more install-and-go.
No doubt for sure, as testers we are more inclined to try all the combos that the average person. Could be a warning about CPL usage though hey @Jeff_Vantrue , might be a bit over the top but every little bit helps the uninformed customer
Just a little note about the CPL usage at the end of the notification would be enough.
I haven't had a chance to check how increasing exposure will work but can't we counter the reduction in brightness of either platepix or even the cpl filter with just turning up exposure?
Yes, it may not look exactly as natural but my goal is more easy to see video in case of a road incident.
