DennisOlof
Rayman.Chan, ok.
Have you tried some sort of heat pipe solution, it could be possible to have some sort of metal, hybrid plastic metal casing, and using a tiny heatpipe to transfer heat.
That way you would be increasing the surface for the heat to escape from the surface of the chip. Usually you can get away with a simple and cheap solution that
most of the time will improve the heat issues.
Checked the video clips, a bit sad it is a .mov container but could work fine. At least it is h264 video in it but the bitrates are kind of low only 11mpbs or is that a settings thing ? Should be able to do 20mbps average for 1080p 30fps
Also the sound , PCM 32000Hz mono 512kbps, better to have MP3 128kbps or AAC, plus PCM is bad, takes up much more space in the file. Also using 44kHz is better, same as on standard CDs. I am sure these more modern chips can do that without any problem.
Or is everything a settings thing ?
The video quality is real good, sharp and nice colors, but it does feel a bit blocky, probably the bit rate issue.
