ND filter for 90 deg
Hondu
What ND filters will fit the 90 deg version with waterproof casing?
kamkar
Denmark
10 years, many dashcams
I don't think many filters fit action cameras when put in waterproof housing, i think i once saw some red filters for underwater use once, but they went on the outside of the housing.
H
Hondu
Even filters that fit the camera without the housing would be ok but which ones? Because mines the 90 deg version I'm not sure if the lens is different etc
@gitup any ideas?
Dashmellow
Uncanny Valley (●_●)
Umpteen
Peau Productions, the action camera specialty house, sells a wide range of filters specifically for action cameras including ND. Perhaps you can find something you could DIY fit to the Git2 or that might even fit without modification?
https://www.peauproductions.com/collections/filters
H
Hondu
Bumping this up. Any eBay links for filters to fit the 90deg lens or even waterproof housing. Really need a ND filter asap now
Dashmellow
Umpteen
As with my Peau Productions post last February, you'll likely need to come up with a DIY solution. There are however many action camera ND filters available on eBay and elsewhere. You can also buy individual sheets of ND material such as theatrical lighting gels or photographic resin plates so you could make your own filters.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=ND+filters+action+cams&_sacat=0
H
Hondu
Thanks for the quick replt.
I have read the filters that fit the gopro hero 3/3+ housing will fit the git2p.
Or can I just measure the lens housing and find one with the same diameter.
I would of thought people would have already tried this and can advise.
Dashmellow
Umpteen
Personally I don't know. I think if anyone knew the answer they would have replied by now but maybe bumping the thread will bring an answer.
Measuring the housing seems like a good idea but you may have to come up with a way to mount whatever filter you purchase if it isn't immediately compatible. UV cement works well for things like this because it can be removed easily.
gitup
China
GIT1, GIT2
Using hero 3+ or Hero 4 case for Git2, you can find many ND filters for this case.
H
Hondu
Does the hero 3+ or 4 housing fit the 90 degree git2? I thought the lens was bigger or sonething @gitup
viofo
Shenzhen
China
A129 Pro / A129 Duo / A119 V3 / A119S / G1W-S / WR1/
Can you confirm the gopro housing fits the 90deg camera?
No, the 90 degree lens is longer than standard version.
H
Hondu
That's a shame. The housing that comes with the camera is every so slightly to big to fit the square go pro housing lens as well.
I think gitup should have made a set.
So nothing off the shelf :(
viofo
Shenzhen
China
It is very hard to develop different case for different version.
Like for G3 model, we have 4 types case, not easy to manage the production.
H
Hondu
Yes that makes sense. Do you know of a filter that fits the housing of the 90deg by chance?
