NETAC microSDXC 128GB and 256GB
lufa6977
Virginia, Shenandoah Valley
Vueroid S1-4K, Viofo A129 Pro Duo, A229 Pro, IR, Telephoto
A friend of mine is using Netac microSDXC cards, so I thought I would give them a try. I ordered these from AliExpress, and since it was my first order, there was a discount.
I paid $47 for the 256GB and $23 for the 128GB.
So far, they have tested well on the bench. They passed the F3Read and F3Write testing. I have run them non-stop for 3 hours in the Vueroid S1-4K at one channel, and all files were present. The cards were no hotter than any other card I have tested. I will begin testing in the car with the Vueroid S1-4K in a two-channel configuration.
Test results are only good at the time of testing. Memory card manufacturers or memory card brands can change the memory type and controller at any time, unannounced.
It is generally best to use the microSDXC card recommended by your dash cam manufacturer.
Netac 128GB
Netac 256GB
Shelf Packs
I just got genuine Netac pro 256GB ordered from official shop. But unluckily it can't be used on my dash cam (Viofo A229 pro 2CH), problem is "Card slow" and no record very randomly.
My Netac 128 has worked well so far. But the 256 has caused a few restarts. I am considering sending it back and requesting a replacement.
Edit: I put the 256 into the Vueroid D22-4K, and the microSDXC worked like a champ. I ran a 4.5-hour test with no issues. The previous failure was in a different brand dashcam.
It was happened again this morning! I tried format SD but the camera just record a short clip and then stop.
Looking for the solution to return seller.
Yes, that type of failure is unacceptable. I got my car back from the shop today (after two weeks) and will be putting 4 dashcams back into it. I am going to test this Netac 256GB on an A229 Plus and see what happens. As I recall, the Viofo products are pretty hard on a microSDXC card.
Sorry to read that you are having issues with the card. Let us know how the return process goes; I bought from AliExpress and have no idea how cooperative Netac will be.
I agree, though i must also admit i rarely live by that rule.
But i have a healthy test / use suite of memory cards so most times easy to find one that work, and i know if things get fishy it is probably time to try another memory card.
IF a system ask for a format in the middle of everything i do not format it again and try again, i go strait to NOT PASS and move on to the next memory card.
