Just to update on my issue with my camera not going into parking mode. After extensive troubleshooting and the help from forum members here (which is much appreciated), I came to the conclusion my hardwire kit was faulty. I got the installer back to check the existing installation and after some frenetic fuse pulling , he came to the same conclusion. The replacement hardwire kit (obtained from Viofo tech support) I had already tested with a separate 12v battery and was switching the camera in and out of parking mode no problems. My installer then replaced the hardwire kit, and (touch wood) everything seems to be working ok. I did have a moment of despair when the camera turned off during parking mode after 2 or 3 minutes even though the timer was set to 30 minutes. the camera wouldn't then then power back on. I figured that as my car had been sat on the drive for a long length of time recently, the hardwire kit battery cut off may have kicked in (set to 12.4v). Took the car for a spin, parked up and the camera, much to my relief, did a 30 minute parking recording as programmed in the settings no problem. Seems to be going in and out of parking mode with the ignition switch ok, so I'm hoping my woes are over.
However, I have a couple of residual questions if anyone can help.
1) Firstly I noticed after the hardwire kit was replaced, a 30amp fuse has been placed by the fitter into fuse 32 - front seat heater. Previously this should have been a 20amp fuse as per the Honda manual. Strangely, I took a picture after the first hardware kit install and fuse 32 hadn't been re-fitted, there was an empty slot.
So it should have a 20Amp fuse in that location according to the Honda manual and this accords with other pictures I've seen of the Honda fuse board, but it is now occupied by a 30amp fuse. Can I just confirm that I can leave this 30amp fuse in place as its a circuit for a 'option' front seat heater which I don't have in any case?
2) I'm also curious to know that if my camera for whatever reason failed to go into parking mode, and stayed in normal driving mode with ignition off, would the hardwire kit 12.4 v cut off still kill the power to the camera?
Any help appreciated.
